Question about Canon imageRUNNER C3220 Printer
Have canon canoscan FB620u anyway to install on windows xp home edition
  • Canon Expert
  • 287 Answers
Hello basljay,
The simplest way (although like killing an ant with sledgehammer) is to go into service mode and do an MMI clear. Walk up to the machine and locate the additional functions key. Now, press the additional functions key once , and then immediately press the 2 and 8 (simaltaneously) and then press the additional functions key again. This three step process show bring up a new menu witha light blue background and several blocks, and at the top of the blocks will say "COPIER". Press copier. Now you have a new menu with several tabs across the top, and other **** filling out the remainder of the screen. In regards to the tabs across the top you will see an item that says "FUNCTION". Press it. Now we are going to focus on the items that populate the greater part of the screen below the tabs at the top. One of the items will say 'CLEAR" . Press it. Now you have a list of things that you can "clear". We are looking for"MMI". It most likely appear on the second page which can be accessed by touching the right arrow ( --->) at the bottom of the screen. Find "MMI" and touch the box for it, and that should highlight it. Once it is highlit, press the "OK" button at the lower right hand corner of the screen. Now power the machine off by the main power switch located near the back of the machine on the right, about halfway down. Or you can unplug and re plug if you can't find the switch. This will basically dump ALL information that the end user has input. This includes the network configurtion, fax data, mailboxes. It is as if you just recieved the machine. Good luck. .......SPINAL.......
Posted on Jul 15, 2008
How can I resset the Id and Pasword for Ir C3220
Posted on Jun 24, 2008
  • Canon Master
  • 13,433 Answers
Seems you accidentally closed the chat
can you send me the ID and password again?
Posted on May 24, 2008
I run windows 7, but I cannot get the driver for my scanner - Canoscan D646u ex (yes, i know, its a dinosaur -- but its not broken)
Unfortunately , the production of drivers stops at W XP .
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html. Easy and safe , no specific knowledge required .
Regards
Jan 10, 2011 | Canon CanoScan D646U Flatbed Scanner
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
I can't find a driver for a CanoScan FB621u that works with vista 64
Try this site.
http://www.pcdriversupdates.com/drivers/updatedrivers.php?t=Canon%2064%20Bit%20Driver&OVRAW=canon%20vista%20drivers%2064%20bit&OVKEY=canon%2064%20bit%20driver&OVMTC=advanced&OVADID=31009232021&OVKWID=165785657021
Oct 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
CanoScan640P ex
If upgrading an existing PC to Windows XP from an earlier versionof Windows, Canon recommends a "clean install" to ensure reliableoperation of drivers. If a clean install is not possible, it isessential that drivers for your existing Canon Hardware are UNINSTALLEDprior to upgrading to Windows XP. After the installation of Windows XP,the drivers for your Canon Hardware can then be re-installed. Canon has released a software utility to uninstall USB and SCSI Scanner drivers for this purpose. Click here to download this utility.It is recommended to consult our Driver Downloads page and use the latest driver for your product. Canon supports several scanner models with Windows XP. Windows XPsupport is offered for Windows XP Home Edition, and Windows XPProfessional.The following older models are not compatible with Windows XPdue to hardware design: IX-3010, IX-4015, IX-4025, CS 300S, FB310,FB61
Source
Sep 20, 2008 | Canon CanoScan N640P Flatbed Scanner
Canon imageRUNNER C3220 Printer Logo
113 people viewed this question
old marine
old marine
