Question about Minolta magicolor 2350 Laser Printer
My magicolor 2350 printer states that cyan is empty and will not print. However, it is set to print even when empty. Also replacing it with a new cartridge does not solve the problem. I can get it to print test pages by asking it to print them at the printer and then forcing a complete reset from the web page. However, it still will not print from a normal driver or from it's direct print interface. The driver state that it is out of toner.
  • tonydb Sep 28, 2010
    I did that and then it said the magenta and then the yellow were out. So I knobbled all three.
    So now it thinks it has three new cartridges and a fairly full black.
    However, now it says the OPC drum is out. However, the statistics page indicates the OPC drum should still have some life left and in any case the printer is set to continue with OPC drum out.
    It still wil not print apart from internal pages on restart up sometimes.
    Any ideas? Can I knobble the OPC drum? It seems to have a broken spiggot that is turned by the gears and forces a break perhaps when new?
  • 857 Answers
The printer uses an "eye" to check the level of toner. You can override this. Open the front door of the printer and take out the cartridge. There is a small round "window" (less than 1/4" in diameter) about halfway along on the right hand side of the cartridge. Stick a small bit of black insulation tape (or scotch tape colored black with a permanent marker) over the window and pop back into the printer. When you turn the printer on, it won't even give that "Cyan toner low" message!
Posted on Sep 29, 2010
  • Jayant Jha Oct 05, 2010
    Is the problem fixed now.
  • 3,083 Answers
Here is an answer from "fixyourownprinter.com":
My magicolor 2350 printer states - 85.gif Re: Minolta Magicolor 2300 by future.child (12/9/04 10:46 PM) reply + / - there is no menu option to reset the cartrige.
If you take a look at the cartrige a look at the cartrige there should be s small metal tab sticking out, if you move this tab back into the cartrige the printer thinks it's new.
have a look at the following link (in german)
"www.express"
Don't know about these tabs, but maybe it will work. Here is another suggestion to try:
0.gif Re: Re: Minolta Magicolor 2300 by Lynn Voyles (edited 6/23/06 7:02 AM) reply +1 + / - To reset cartridge to read full. Also check out this link. Step 1 and Step 2 explain how to get to the new cartridge sensor and do the reset. Just remesh the gears on the small black plastic sensor with the white gear. Be carefull on reassembly to ensure the tab on the black sensor is properly fitted into its end cap slot. During or after reassembly, do not turn any gear after the two set of gears are properly meshed. Otherwise, the cartridge will not register as new upon installation.
http://www.futuregraphicsllc.com/lit/tg/minolta_2300_dl.pdf
This also works with the Epson Aculaser C900/1900 cartridges. Same cartridges.
And here is the link:
http://www.fixyourownprinter.com/forums/laser/25521
Good luck, and hope this helps.
Posted on Sep 28, 2010
Hello. I am getting a message that my yellow toner cartridge is empty and the printer (Konica Minolta 2300W)refuses to print out anything, even though I got it into the B/W mode. The complete message...
It won't print anything if one cartridge is empty, even black when the colour is empty. Are you using new or refilled cartridges? The cartridge has a chip on top that counts your number of prints, so it could feel full, but has reached it's end counter. Try another cartridge. That should solve your problem
Aug 06, 2010 | Konica Minolta magicolor 5430 DL Laser...
Will PIXMA MP640 print with an empty cartridge
No, it will not. I have this printer and last week I ran out of cyan. Even though i only wanted to print black and white documents the printer would not print anything until I replaced the cyan cartridge.
Jun 25, 2010 | Canon Office Equipment & Supplies
My magicolor 2350 has cyan print problem
replace the cyan image unit might go a bad one
Oct 04, 2009 | Minolta magicolor 2350 Laser Printer
I have magicolor 2300 DL.I just replaced Cyan
make sure your cartridge is not stuck and pushed in all the way in printer. If it gets struck it will dump ink out and waste it.
Aug 19, 2009 | Konica Minolta magicolor 2300DL Laser...
Minolta EN 2350 is not printing. Printer Display reads Processin
IN PROCESSING mean its doing the internal house keeping are your image units and toner OEM no other error code, reseat all the toner and image units, Replace non OEM Cart. try this site for latest drivers etc.
Self Help Product Support Konica Minolta Business Solutions Inc
Nov 18, 2008 | Minolta magicolor 2350 Laser Printer
Need Override for Low Toner Message Minolta QMS 2300
It depends on the model. The 2300 series using a mechanical mirror on the cartridge itself. A tab needs to be moved the mirror slid back to home. The 2400 series & newer uses an IC that you need to replace. when you buy your toner to refill the cartridge make sure you get the IC with it. Russell
Aug 21, 2008 | Minolta magicolor 2350 Laser Printer
Question about mc 2350 cartridge
I just got done replacing my toner.  You'll need to change toner and most likely all of them. There is no other solution.  I refill mine by buying the bottle toners.  It can be messy and you'll need to take some parts off the cartridge to get to the opening plug and reset the lever so that the printer knows the cartridge is full.  It is cheaper than buying a toner. The cartridge has a life of about three refills.  Anyway hope this answers your problem.
Aug 07, 2008 | Minolta magicolor 2350 Laser Printer
Printing toner is very low
Most manufactures supply the new machines with a starter toner. If you replace them with genuine new Minolta cartridges you should yield a lot more!
May 31, 2007 | Konica Minolta magicolor 5430 DL Laser...
Minolta magicolor 2350 Laser Printer Logo
187 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
