Question about Troy Bilt 5.5hp Self Propelled Mower
Troybilt 6.5 -self propell belt came off..how do i put it back on
    Scholar:
  • 150 Answers
I assume the front wheels are the drive wheels. There is a cover over the belt, on top you'll see a plastic cover, if it drives from the bottom you'll have a metal cover under the deck. Eigther way remove that cover which ever one it is. This will expose drive and give you acess. They tend to collect alot of debri and rust clean before remounting or repacing belt.
Posted on Sep 28, 2010
What would cause a troybilt self propelled mower 12a-466m011front wheels to lock up when pulling back? Also why would this continue when mower is off?
There could be several things. Have you recently changed the belt? Was it an OEM belt? i have seen loose trannys cock in such a way as to put the belt in a bind and not let it slip when reversing. More likely is that there are dogs on the wheels and one or both aren\'t releasing.
May 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troybilt self propelled mower front wheels lock up when pulling back
most have small leaf springs that let it toggle back and forward, if they brake can cause this problem. Then it may just need the wheels removed, clean the parts and lubed
How do you adjust the drive cable on a troybilt self pro pelled md# 12A-446A711?????
Unfortunately, you cannot adjust it. If you have an extra space to move it lower than it was on the handle you can do that. You might have to get a new cable. Or the belt may need to be replaced. Do you hear a grinding noise when you try to engage the self propel? If so the transmission may have gone out. The most common problem is that the belt has jumped off from where it needs to be and it is no longer turning. To check to see if the belt is off, you will need to put the mower on its' side, the side with the oil level check is the correct one. You will need to loosen the cover over the drive belt. This is done by loosening one or two bolts that hold it in place.The bolts should have 3/8 hex heads. You may have to maneuver the cover a bit to see if the belt is in place. If the belt has jumped above the pulley for the self propel then you will have to install a new belt.
Mar 26, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybilt xp, and the self propel fontion
Does the drive shaft going to the wheels turn at all?
If it doesnt you may have a unsecured pulley on the engine.
If the shaft does turn when you engage the tranny your next stop is taking the wheels off and checking the wheel clutches. Sometimes called sprag clutches. They are probably both stuck in the unlocked position. You need to clean them up by removing all the greasy material covering them and putting them back together with just a few drops of light oil.
I hope this helps. Good luck and be careful!
Jul 28, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My self propelled high wheel mower doesn't go
If this is a TroyBilt 34068, check your belt to make sure it is still on the transmission pulley. If the belt is in place, start it up, engage the transmission and observe both axle ends where they protrude from the center of the wheels, if one of them is turning, you have somehow lost the square key that locks the wheel to the axle. Replace the key and you will be good to go
Sep 15, 2009 | Garden
Troy Bilt 33'' Replaced the self propel v belt and now the mower will not disengage from drive mode, also very hard to shift gears
If you didn't by the Troybilt belt, try that. I had the same problem with a Napa belt. Going into drive as soon as I grabbed the operator presence button, not coming out of gear etc. When I switched the the Troybilt belt, the problem went away.
Jul 17, 2009 | Troy Garden
Need help with belt on Troybilt self propelled push mower
Try removing the pulley in order to put the belt back on.
Jim
May 29, 2009 | Troy Garden
Self propel belt is too tight to put back on
the best way to install it is to put it on the motor shaft first and then to start putting it on the large pulley at the top and roll it on these belts can be hard to put on.
Jan 05, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Troy Bilt 5.5hp Self Propelled Mower Logo
195 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
