Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
Lower key are activated e.g. typing p gives me * and o gives a 6, U give a 4 etc.
  • marilynnl930 Sep 28, 2010
    Thanks - really fast and helpful!
  • 4,737 Answers
What is the operating system installed on the Laptop? Did you make any changes recently, like installed new programs or uninstalled/deleted something from the computer?
I would suggest you to check the Fn key. Press Fn+Numlock (Num) key simultaneously and try typing again. Sometimes only pressing the Fn key does the trick.
Well, let me give you a hint, open up notepad, then press Fn+Numlk and again type something in the notepad including those defective keys, if only once pressing is not helpful, press the keys (Fn+Numlk) twice and try typing again. Do the same only with the Fn key, press once and type in the notepad.
It's also possible that on of the Shift Key is stuck or pressed. Check both the Shift keys, press 5 times on each of the Shift keys, if something opens up when press 5 times, then it's not the problem (simply close the opened window, don't make any changes, it'll be hard for you to revert them). If nothing happens, then it's should the key must be defective, you need to take out the button and clean it with a cotton dampen with acetone/alcohol.
If nothing mentioned is helpful, let me know with more details.
Good luck.
Thanks for using FixYa.
Posted on Sep 28, 2010
WHAT ARE THE KEYS OF ERROR CODE OxCOO4EOO3
Are you sure you're typing all the letters correctly? Look closely at B and 8, G and 6, etc. Product keys do not contain 1, I, O, or 0.
Are you using the correct Windows 7 key? A key for XP or Vista will not work with Windows 7. A Home Premium key will not work with Ultimate, etc.
Note: Make sure you are not installing windows on more computers then allowed.
Call Microsoft Using the Manual Phone Activation
If you have trouble activating Windows 7 you can call Microsoft to activate by doing the following:
1. With Windows running click Start, then in the Search box type: slui.exe 4
2. Press Enter on your Keyboard
3. Select your Country.
4. Select the Phone Activation option, then call the number given and hold for a real person.
Jan 19, 2015 | Computers & Internet
Adobe photoshop cs3 serial number 1330-1751-1921-7520-1721-1350 activation 4373-2829-9684-6024-9758-5702-4895 please send me a authorization code ;) amrbasha_6@hotmail.com
1)use the keygen to generate a serial
2)use that serial to register
3)cs3 will then give you a few options you select activate by phone
4)a serial number will be provided by cs3
5)you paste this into the lower box of the keygen then select generate
6)the number generated will be what you use to activate the software
note all this will need to be done without closing down the setup process because the serial numbers will only work with the codes that generated them
hope this helps,it is really simple once you do it once
Mar 31, 2011 | Adobe Computers & Internet
Heater says lower sescor failur what is that
1) For the best answer possible, post what type water heater you have.
Gas or electric. Tank or tankless. Undercounter, tabletop, RV, indirect, solar-assisted, etc.
Information should be on product label
Give as much information as possible so experts are not guessing.
2) If you give brand and model number (not serial number), we can possibly pull a manual that could match your product and simply read the troubleshooting steps alongside you.
This will help us give the do-it-yourselfer as much help as possible.
3) Pull out your product manual. Look at your manual for troubleshooting steps, error codes, and remedies.
4) Go to manufacturer's website and look for manual.
Most manufacturers post manuals, and those that don't are selling another manufacturer's product.
http://waterheatertimer.org/Water-heater-manufacturers.html
5) Whirlpool has contact us page:
http://www.whirlpoolwaterheatersupport.com/support/contact.aspx
6) If this is Whirlpool electric-tank-type energy-smart, then the error code probably means that temperature sensor locate just above lower element needs to be replaced.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Whirlpool Water Heaters
Uncaught expception
Instructions for unlocking BlackBerry Curve 8520 in UnlockGenie.com
Warning! The Wireless Mode MUST BE OFF before performing the given SIM Unlock instructions in order to avoid causing the device from becoming defective.
How to turn Wireless Mode Off:
1. Scroll to the Airplane Icon (Turn Wireless Off.)
2. Press Select.
3. Wireless Mode will turn off.
How to SIM Unlock the device:
1. Go to the "Options" screen
2. Select the "SIM Card" option
3. Type ALT-MEPD (hold ALT key while typing the 4 Letters, M-E-P-D)
4. Release the ALT key; it should then display a list "SIM, Network, Network Subset, etc..."
5. To select "Network" type ALT-MEPE (since E is the Key that gives 2 when shifted)
6. Release the ALT key, it should then ask for the code
7. Enter the unlock code provided.
Note: In case of difficulties when entering the code please try the alternative instructions below:
Alternative Instructions how to enter the unlock code.
***** You must have a SIM card in your phone to complete these steps. We recommend using the SIM card that your phone is currently working with *****
1. Go to settings
2. Go to options
3. Go to advanced options
4. Go to SIM card
5. Type MEPD (not case sensitive) (you will not see text appear on screen while typing)
6. Does it say Network active? If so your phone is locked
7. Hold the ALT Key while typing in MEPE (not case sensitive) (you will not see text appear on screen while typing)
8. It will say "Enter Network MEP Code, then you type in the 16 digit unlock code, press in the jog dial to confirm
9. Your phone is now unlocked
Jan 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
Give me a serial number of quick heal antivirus plus to download update
1.copy thislink in browser n download (quich heal antivirus plus 2009):
“http://download.quickheal.co.nz/builds/2009/qhnt2009.exe”
2.then install quich heal in system.
3. after installation will give 3-options: 1- update now 2- activate now 3- install firewall
click all 3-options
4. in activation process give 3-options: 1.activate 2.re-activate 3.
5. choose only one option that is- RE-ACTIVATE
6. PUT SERIAL NO MENTIONED ABOVE(20-digits):089F1 1B986 06049 B0F87
7. put activation no mentioned above:FB646BB048
Jun 22, 2010 | Computers & Internet
I have lost product key for my win xp os cd. How could I find the key?
Hello <
if your Windows XP CD is genuine then you just need to contact Microsoft support site. They will give you product key and if you want some other heck like Pirated XP CD key or crack etc. then In fixya we are not giving any such type of answer.
You can also find out key in MY Computer properties windows.
Sep 22, 2009 | EXP Computer EXP CD-RW Station CRW 2400U...
MS Office Activation key
Sol1: Open word -click the pearl button on the left corner - click word options - clik resources - try activating it.
There are two methods for activating Office; telephone and the Internet which is the easier of the two methods. To activate the product by using the Internet, follow these steps:
For Microsoft Office 2007, follow these steps:
1) Start any office program.
2) In the Office Activation Wizard, click the “Activate by using Internet” option, and then click “Next”.
3) Click “Submit” to send your information to the Microsoft licensing servers.
NOTE: When your information is validated, the “Activation Complete” page appears. Then, you can use the Office programs. You will not have to activate Office in the future.
4) Click “Finish”
Please follow the below guidance for telephone activation for your version of Office:
1) Start any Office program.
2) In the “Office Activation Wizard”, click the “Activate by using the telephone” option, and then click Next
3) Read the “Microsoft Office Privacy Policy” page, and then click “Next”.
Note You are not required to read the Microsoft Office Privacy Policy to continue these steps in Microsoft Office 2007. A link to the Microsoft Office Privacy Policy is provided so that you can read it at any time.
4) In the “Select your location” list, select a country or region. Call the telephone number that is listed on line 2. The customer service agent will ask you for the installation ID and will give you a confirmation ID in return. Type the confirmation ID in the boxes provided.
5) Click “Next”.
6) On the “Activation Complete” page, click “Finish”.
Else you can call (888) 652-2342
Hope it helps !
Thank you !
Sep 14, 2009 | Microsoft Office Professional 2007 Full...
Computer asking for activation key, power failure at home
if its vista or xp ur activating
When you try to log in, you should be presented with a window that gives you four options:
1. Activate Windows online now --> (this will try to activate with whatever key you already have installed)
2. Buy a new product key online --> (self-explanatory)
3. Retype your product key --> (this is the same as "Change product key" and will give you the opportunity to enter a new key if you want to activate with a key that's not yet installed)
4. Show me other ways to activate --> (this is will give you two more options
a. Use my modem to connect directly to the activation service
b. Use the automated phone system
I think you'll want to choose the 4th one in the first window and the 2nd on in the next window. It will give you a new installation ID, so you can phone activate.
Apr 07, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Windows activation error code 0xC004F058
Quick search got this answer:
Step set #1
1) Open Internet Explorer
2) A Browser will open, type: %windir%\system32 into the address field
3) Find the file cmd.exe
4) Right Click on the cmd.exe and select Run as Administrator
5) Type: cscript slmgr.vbs -rilc (It may take a long time for this to complete, please be patient)
6) Hit the Enter key
7) Reboot 2 times
Step set #2
1) Open Internet Browser
2) Type %windir%\system32 into the browser address bar.
3) Find the file CMD.exe
4) Right-Click on CMD.exe and select Run as Administrator
5) Type: net stop slsvc (it may ask you if you are sure, select yes)
6) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
7) Type: rename tokens.dat tokens.bar
8) Type: cd %windir%\system32
9) Type net start slsvc
10) Reboot Twice
11) Windows Vista may require you to enter a Product Key [use the Certificate of Authenticity (COA)] SLP Product Key found on the sticker on the side or bottom of your computer and activate. Use the Activate by Phone method outlined below.
From the Desktop:
a) If you have access to the Start button: Click the Start button, and type in "slui.exe 4" in the search field and then press the "Enter" key. This will bring up the Activate by Phone dialog window. Follow the steps provided by the window. The phone activation process should only take about 6 minutes.
b) If you do not have access to the Start button: Reboot and login to Vista, a dialog window will come up. In that window, click the option "Access computer with reduced functionality". Once you do that, Internet Explorer or Firefox browser will open. In the address bar type "c:\windows\system32\cmd.exe" press enter, a new window will come up, type: slui 4 and hit enter and follow steps to Activate over the Phone.
This all is if you have a true bought copy of Vista. If you have a pirated version, Im sorry to say I cant help.
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
Can't log into Win Vista Home Premium
Call Microsoft.
Microsoft Windows Vista Consumer Product Activation Phone Number:
1-866-740-1256
Good luck with this.
Mar 19, 2009 | Gateway MT3705 Notebook
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
201 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
