Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
I have a Ryobi 137 trimmer and the whipper head has lost its spinning speed therefore it won't cut the grass. Any ideas where the problem lies?
    Scholar:
  • 150 Answers
You may have too much string out. Try cutting off some if your machine auto cutting blade is gone or really dull
Posted on Sep 28, 2010
Why does my weed eater stall
It may stall for many reasons. Is the frass too tall, too thick or the stems are too solid? The whipper can cut most grasses but some are hard grasses that put considerable pressure on the machine that it locks the spinning string feed, therefore stopping it. Other reasons are due to the type of fuel (fixing inconsistencies, too much or too little oil in the fuel or the fuel has been left out for too long and is somewhat a little exhausted. You note this by hard starting. The engine could be labouring because it's not tuned properly. Try starting it and do a manual tune-up. See it stays running at idle and then do some accellerations before it is taken out to cut grasses.
Aug 12, 2014 | Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
TB70ss clutch
Check to see if there is any material collected around the base of the head, around the tube that provides the energy to spin. It may cause the power to be diminished a great deal, so that must be cleaned away thoroughly. Check to see if you can spin the head freely by your hand, without the motor being on. If not, it may need lubrication down the indide of the power shaft. A light grease would do that, or even a heavy oil poured down the shaft, but not too much.
Sep 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
I have a Ryobi RLT30CESNB whipper snipper. Had it for about a year. The motor starts and runs okay. Just yesterday, all of a sudden, the head stopped spinning when I gave it some throttle. The motor still...
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 05, 2012 | Ryobi Garden
My Grass Hog trimmer was working fine then all of a sudden it stopped cutting. The string no longer spins around. I just hear a werrrrring sound. I just bought it last summer.
I can tell you what is is, the belt came off inside. Mine is doing the same thing, I took the case off and looked inside, the belt had come off the metal wheel. I put it back on but it keeps coming off. Im thinking theres a piece I must have lost that helps hold it on. Thats what Im looking for now. If you can get the belt back on and to stay on then it will work again.
Aug 20, 2010 | Black & Decker 14" Grass Hog Xp...
My whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Mar 01, 2010 | Garden
Have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
202 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
