Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Beeping sound and f8 displayed
Power went out, went power was restored the displayed board showed F8 and there was a beeping sound. I tried plugging it out several times but the same thing continued. it is a Kenmore wall mounted self-cleaning oven Model #911-4584690, serial #4H129484R
  • 525 Answers
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
Posted on Jun 16, 2008
My Fridgidaire double wall oven is beeping every 2 minutes while displaying FB. How do I stop the beeping?
Sounds like an F8 error- problem with the door lock/latch (for self-cleaning mode). Could be the mechanism, control board, or wiring in between. Try unplugging (or turning off the breaker) for 20 minutes to an hour, and plug back in to see if it will reset itself. If you're lucky, you might be able to just clean gunk out of the latch area, but probably need a repair call.
Oct 20, 2017 | Ovens
I have a frigidaire wall oven which was on bake accidently hit clean and immediately hit cancel. Sounds like fan running and started beeping and F8 appeared. Turned off breaker and turned back on same
Hello - Typically error code F8 indicates that there is a communication error between the user interface and the control board. Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Nov 23, 2012 | Ovens
My oven door is locked closed. Also, it reads F8 and beeps. In order to stop the beeping, the cancel/off button must be hit. When I do that, the fan turns on for about a minute and then stops and goes back...
The control board runs self checks about every 10 seconds to check the oven codition,and what the F8 error code means is it has detected a problem with the control board itself and it needs to be repalced
Gene
Aug 04, 2011 | Jenn-Air JJW8430D Electric Double Oven
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire double ovens F8 error and beeping
good day,
hope this link below will solve your problem.
ovens
Mar 23, 2009 | Frigidaire PLEB30T8A Electric Double Oven
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
338 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
