My mp3 player only works when it is plug to the computer but when i unplug it from the computer itgoes straight off and it does not come back on
  • 8,596 Answers
There could be a genuine problem with the player's power supply circuit, but it may just need to be restored - the DB could be corrupt, and this is affecting the player's performance.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If this fails, find out if you are still under warranty from the store or manufacturer.
-Tha Mp3 Doctor
Posted on May 24, 2008
Hi, I have unplugged my MP3 player from my computer and it does not respond to any switch. If I put it back into the computer it reads that it does not recognise the removable device . Can you help? Thanks
Initially, you can hold down the power button down for 20seconds to do a reset.
You should do the "safely remove" procedure when unplugging the MP3 player from the computer's USB port, otherwise it will get fried and damaged over time. If you have just been simply pulling the plug off all these times, then I guess that was what happened - the battery got fried. Anyway, just try to plug your MP3 player to another USB port on the computer or better yet, to other computer's usb port.
Please let me know how this goes.
May 30, 2010 | SanDisk Sansa e250 MP3 Player
Laptop not recognizing mp3 player
First of all unplug power chord from computer. Remove battery if it is a laptop. Unplug device from usb.
wait ten minutes, plug all back and restart all, see if this work
Mar 22, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
MP3 does not switch on, not even when plugged into computer
There is a small reset button on the back. You need to reset it with a needle or a toothpick and then it works again.
Jun 16, 2009 | Philips SA5125/37 MP3 Player
Laser mini mp3 player 4GB
I found that MP3 players need to be plugged into a USB PORT not a USB HUB. Good Luck!
Mar 19, 2009 | Laser MVP-1G MP3 Player
Sansa wont turn on!!
Hey so soz but what u can do is just plug it in and let it charge overnight and then try it again and it should turn
so hope thizz works guud luck
Sep 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa Fuze not working anymore
My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
Jul 17, 2008 | Audio Players & Recorders
SANDISK MP3 PLAYER
Unplug the sansa and turn it off. Then plug it back into your computer. If it still doesn't recognize it, unplug it and change the usb setting, make sure you highlight it and then press the inner circle or it might change back into the other setting. This worked for me.
Jul 12, 2008 | SanDisk Sansa e260 MP3 Player
Insignia ns 2v17b froze and won t turn back on? PLEASE HELP!!!
the solution to this is to unplug the batery from the player itself. you have to open it by taking a jewellers screwdirver, pry out the rubber cover from the back. it is the only one that is on the battery cover. after doing so it will reveal a philipps head screwdriver. simply unscrew it and unplug. be very careful and pry the sides of the battery cover slowly sliding and prying downwards.. unplug and plug back in again.
the solution to the other problem here is that you guys and gals are unplugging the player prematurely meaning. You just simply unplug it from the your computer w/o safely removing your hardware. by doing this straight unplugging from the pc, yu are corrupting the hard drive on your usb and eventually end up breaking it.
Apr 27, 2008 | Insignia NS-DV2G MP3 Player
Won't turn on or connect
that happened to me too. i unplugged it and turned it off. once it's off i plugged it back in and it worked. hope it helps.
Jan 11, 2007 | SanDisk Sansa e260 MP3 Player
 Grubhead
Grubhead
