Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
I have a ge 42 inch rear projection tv. The colors are crossed and I was wondering if this is bnecause of the lenses out of alignment? if so, how can I adjust it? there is no setting for alignment.
    Sergeant:
  • 270 Answers
It is possible, that the type of connection you have to your TV are crossed.
With COMPONENT cables, you have 3 plugs, red green and blue.
If this is the case, correct the plugs location to the correct plug.
Lens alignment results in a fuzzy (diffused) picture.
outside of that I too am at a loss.
good luck and don't forget to vote!!!
Posted on Sep 28, 2010
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
The blue lense is off by 2 inches and can't adjust it. The picture has a blue shadow.
The tv have a problem known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have 3D pictures or colors shadows.The tv convergence board it dead.Require changing 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Panasonic PT-47WXD63 47 in. Rear...
Unable to align cross hairs on the blue lense. Dose the lense need to be replaced?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
May 08, 2010 | Hitachi 50UX57B 50" Rear Projection...
My Toshiba 42H83 has developed a color problem. The color blue is about an inch off the other colors, the picture looks like a 3d movie without the glasses. I have used the touch focus button on the...
Alot of rear projection t.v.'s have a convergence option in the menu on the t.v. There you can set the try to set the colors back how their supposed to. Mine has a cross in the middle of the screen and you just have to try to get all 3 colors to line up. Unfortunately, the actual lens inside mine has to be aligned so it doesnt work. Just something to try though, hope it helps.
Jan 05, 2010 | Toshiba 42H83 42" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
1995 zenath 50 in. projection tv(need help to align w/remote
It appears that you can get a wealth of info on your Zenith here:
Zenith info
Mar 04, 2009 | Zenith IQB50M90W 50" Rear Projection...
JVC HDTV Pictrure Distortion
Your TV needs to be calibrated. Rear projection TVs are very sensitive to movement. They have 3 color canons that need to be precisely aligned so that the colors overlay each other. They are like three projectors all aimed at the same screen.
If you were to enter the User Menu on the TV, you should find an alignment/calibration choice that will re-align the colors using some on-screen help.
If you are not able to resolve the situation on your own, a certified ISF Calibrationist should be called.
And, since you've bought this TV used, it should be cleaned by a professional (the canons, lenses, etc.)
Apr 07, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
42 inch toshiba covergence problem
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 28, 2007 | Toshiba 42H82 42" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
