Question about Dryers
Drive belt broke
Where can i find one GE SELECT
    Genius:
  • 1,073 Answers
Need the model number
Posted on May 24, 2008
Dryer only runs while holding start button in
We have a Maytag Epic dryer with the same problem (Model MED9800TQ0). Pulled out the control board yesterday and saw that the weld had been blown right at the motor relay (burnt marks surrounding the area on the flip side of the board where the relay attaches). Do you suggest we replace the motor relay or just try to re-soder that part on the board? Also - should we be concerned as to how this happened (that it was something elsewhere that caused it to blow)?
Jan 16, 2013 | GE Dryers
Belt broke on dryer where to get them
have you tried contacting the manufacturer or checking their web site on the parts page?
Jul 20, 2012 | GE Dryers
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
The drive belt broke and i cant get the new one on.
they are tough to put on but start by putting the new belt on the motor pulley first then with gloves on so as not to pinch your fingers start the belt on the larger pulley on the drum and just work it on by turning the pulley as you go,it will go on, but it will be very tight when its finally on both pulleys
Jan 01, 2011 | GE Energy Star WCVH6260F Front Load Washer
No spinr and agitate
Check the drive belt to see if it is broke or has slipped off the pulley. Here is a link to the part in case you need it.
Dec 25, 2010 | GE WDSR2080D Top Load Washer
Ge dryer has heat and turns on but doesn't go around: Does not spin around.
Your drum belt has probably broke. If it's not squealing or burning rubber, then it probably broke. Douglas
Sep 13, 2010 | GE Dryers
Belt fell off - can't see how to attach it GE
place belt onto motor shaft, then slowly turn drive wheel while holding belt into place. when on adjust to correct position so belt stays central
Feb 11, 2010 | Washing Machines
Washing machine motor fan belt broke
Either Maytag or Ge or older than 87. Inspect pumps and pulleys before buying a belt to save a trip. If the wear isnt too bad a part number is on the belt and bringing the belt will save a trip too. Replacing the belt, first lace it on the pump and motor and finally the large drive pulley in the center, it will be easier.
Sep 07, 2008 | Washing Machines
Dryers Logo
49 people viewed this question
Top Dryers Experts
