Question about Ovens
CANNON CORDON BLEU - CLASSIQUE OVEN approx yr 1989. ignition keeps clicking in main oven and wont stop.
3 Suggested Answers
SOURCE: Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Posted on Nov 26, 2009
  • 1156 Answers
SOURCE: I don't have the manual
Hi, thanks for posting your Question.
To be able to help you out, ovens are of different types..You will need to state the type and the model of your multi oven,sothat we can be able to help you out..
Thanks ..
Posted on Jul 07, 2011
Main oven works but the ignition keeps clicking while oven on
check the operators manual or with a servicing agent
being gas it may require the clicking to reignite the gas when the temp starts to cycle or there may be a problem in the control system for the gas operation
May 04, 2016 | Ovens
The main oven ignition keeps clicking away after the oven has been on a few minutes. It will click away for ages before gradually slowing down and stopping.
Your stove has a faulty sensor that is used to detect the flame of either the pilot that gets lit by the ignition or the burner itself. Without knowing the brand and model of the oven, it will be impossible to know which parts are affected.
Dec 03, 2014 | Ovens
I have a cannon p[rofessional. When i turn the oven on the burners ignition keep clicking . Any ideas?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 28, 2010 | Ovens
Ignition not turning off once oven lit
It is normal for the ignitor to stay lit while the burner is going...There is nothing wrong there...
heatman101
Apr 07, 2010 | Ovens
The igniter on my stove wont stop clicking?
I would check the valve switches. Chances are one of them is stuck. If they are not overly expensive I would recommend replacing all 4 while it is apart.
Eric
Feb 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
Nov 24, 2009 | Ovens
The timer sound on my classique oven has suddenly become so soft I can barely hear it
turn mains off for 1 minute nd then restart it will default to orignal settings
Oct 28, 2009 | Fisher and Paykel AeroTech - OS302M...
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Bottom oven on Cooker Cannon c60gcw will not ignite, continuouos sparking and no gas when knob turned on
Fault caused by trapped and therefore cut wiring to main oven valve at bottom rear of cooker causing wiring overheat melting and open circuiting electrical supply.
Sep 15, 2009 | Ovens
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 | Ovens
Ovens Logo
130 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
