Question about Sony XR-CA430 Cassette Player
I have a Sony XR-CA430X and whilst the radio and cd input is working fine, the display is not illuminated, so i cannot see radio station name etc. Is this likely to be a fault in the fascia back light? if so how can this be checked, or is there anything else to check first?
  • andrew_pont Sep 28, 2010
    Contacts on both parts (the main body, and the front face) look nice and clean, and all undamaged. I have pressed the reset button but to no effect.
  • 15,935 Answers
All you can do on the user-end is reset the unit. Refer to your owner's manual for the reset procedure
Also... check the contacts on the faceplate and chassis to make sure they are clean and not bent.
Thanks!!
Posted on Sep 28, 2010
  • blueextc3221
    blueextc3221 Sep 28, 2010
    Then I'm afraid the backlight (or invertor) has failed - and it will need professional servicing.
Lost radio illumination in 2008 HHR
Internal workings of the radio, if the radio is operating fine then your bulbs/lighting inside the radio is bad as the lights come on with power to the radio. Normally they don't replace this and just swap the radio which is expensive. If the vehicle is still under warranty I would take it back and even if its not its an 08 go and raise hell to the dealer and force them to buy you a new radio!!
Nov 11, 2011 | Cars & Trucks
I cannot get the AM radio stations to play or the CDs to play on the AIWA XR-M10. FM stations come in fine.
as for the am radio you need to connect the am aerial to pick up am frequencies as for the cd player need a bit more info on that
Oct 14, 2010 | Aiwa XR-M10 Shelf System
The display went out on the radio/cd player of our 2005 Mazda 3. The decorative light works by the volume knob but we cannot tell what station the radio is on or any of the functions because of the lack of...
this happened to me after 2 years of having my 2006 Mazda 3, luckily i was still within warranty. the entire LCD had to be replaced in mine
May 12, 2010 | 2006 Mazda 3
RDS failure?
some stereos you have to input the name of the station yourself.
May 05, 2010 | Sony CDX-GT310 CD Player
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
Display doesn't display info....just bright light
Have you tried resetting the unit? Remove faceplate and push the reset button with a ball point pen. If it's a bluetooth model there is a different procedure.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 25, 2017 | Sony CDX-M610 CD Player
How do you work the Aux input?
when something is plugged into the jack (mp3 player ect) there should work when you cycle through the options of the deck such as cd, radio, There should be an aux option when it is plugged in.
Feb 09, 2009 | Sony XR-C210* CD Changer
Car stereo displays 000ZAA
000ZAA:
remove front panel and press reset button with ballpen
Jan 10, 2009 | Car Audio & Video
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
May 25, 2008 | Car Audio & Video
Sony XR-CA430 Cassette Player Logo
116 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
