Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag mtw6600tqo f50 lights flashes - Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
2 Suggested Answers
dniro592006
  • 121 Answers
SOURCE: maytag top load mtw6600tqo fills for a bit then
F50 - Fill Cycle / error on level switch I beleive
Posted on Jun 12, 2009
What is a balance ring for matag washer mtw6600tqo
The balance ring is a liquid filled hollow tube of plastic that encircles the top of the wash basket. It is what sloshes when you vigorously move the tub back and forth. Even though they are pretty indestructible they can still lose their fluid. When they do a tub can literally leap from a machine. Some are replaceable. Unfortunately yours i believe is not. You would have to buy a whole new inner drum basket to replace yours, I think.
Jan 26, 2013 | Maytag Washing Machines
Display is flashing F then 50.
F50 is the error code for a bad conyrol board and it will have to be replaced and you can get it at a local appliance parts dealer near you with the model number.
Hope helps.
Jul 03, 2011 | Maytag Washing Machines
My washing machine starts on normal and within a minute it starts to flash F50. what does this mean?
Check Maytag.com for computer codes relating to your device. They provide full information for all of their machines online and this sounds like a common code number.
Oct 08, 2010 | Maytag Bravos MTW6600T Top Load Washer
F50 fault on maytag MTW6500TQ washer after apprximately 1 minute of startiong cycle
Two things cause the dreaded F50 code. (motor)
1. The machine control
Bravos MTW6600T
http://www.repairclinic.com/SSPartDetail.aspx?s=t-Maytag+MTW6600T+-%3d%3di1469076&PartID=1469076
2. The stator
Item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136402&diagram_id=1303991#d1303991
The upper cover of the stator comes in kit form and has been known to also cause the dreaded F50 code.
http://www.appliancepartspros.com/part_details.aspx?part_id=4327312&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5136402%26diagram_id%3d1303991
All of them are some what costly repair(s) in my book but cheaper than a new machine.
I have yet to change a Stator for an F50 Code.... but have changed a lot of machine controls (most often failure) and stator cover kits (occasional failure) that corrected the problem.
Just being honest. Thanks for using FixYa!
Kelly
Oct 13, 2009 | Maytag MTW6500TQ
Maytag Bavos MTW6300TQ0
Bravos MTW6600T
2. The stator
Item 17 this link:
Sep 14, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Sep 01, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer model # mtw6600tq0 error code f50
Bravos MTW6600T
2. The stator
Item 17 this link:
Kelly
Jul 29, 2009 | Maytag Bravos MTW6600T Top Load Washer
Have a Canon F50 Multipass. The alarm light is
Attempt to re-surface any replaceable rollers with a brillo or Scotch Bright pad ONLY if you are unable to locate replacement rollers. This will reduce the life of the rollers further and can permanently render them defective
Any rollers in the paper path and in the tray area(s) should have texture and should not be glossy or completely smooth with the exception of hard-plastic rollers used only as guides.
Apr 28, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Washer starts, then shows fault code
Bravos MTW6600T
2. The stator
Item 17 this link:
Feb 21, 2009 | Maytag MTW6500TQ
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
