Question about Cameras
It shows me a lense error dialogue when I turn it on!!!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 28, 2010
My lumix dc20 when turned on displays this battery cannot be used. Any ideas please
1) Incorrect battery, use genuine battery. 2) My Canon 400D had a similar problem. Checks showed that I had a damaged standard 18mm to 55mm lense unit, and also gave me "change battery" error message. I had a similar problem with a 70-300m lens. The camera main lense needed repairs, the Tacumar lense was not worth repairing. Have a camera specialist check your camera and more specific the main lense unit.
Jun 08, 2014 | Cameras
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Fee error on d300 with Sigma lens with aperture ring
Turn the aperture ring on the lens to its smallest setting (largest f/number) and then forget it's there. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
Oct 13, 2012 | Nikon D300 Digital Camera
If envelope printing Canon PC-D340 All-In-One Laser Printer incorrect paper size problems.showing
You need to make sure the paper size and that of the printer matches in the dialogue box.
i.e assuming you a printing an envelop DL size, make sure your envelop is the exact size you choose in your page layout.
secondly, open the properties in the printer dialogue box, where you have letter, change the default "letter" paper to you envelop size.
Note: if your envelop size is not accurate and the actually printed, you will still receive "incorrect paper size" error. At this point I turn of mine and turn on again.
Jul 17, 2011 | Canon PC-D340 All-In-One Laser Printer
Conon powershot A450 lens error
Try to use fresh batteries, and push the barrel in and out when it turns on to see if the 'binding' of the focusing gear can go away when you do this manipulation of the barrel.
If the error continues, maybe the camera needs service by Canonusa.com.
I could not, unfortunately, find a reference for an a450 on the website, though. Is that an older model?
Jul 29, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
When I turn on the camera, Lens error shows up on
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 27, 2009 | Nikon Coolpix S210 Digital Camera
Lense error, restart camera
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nov 22, 2008 | Canon IXUS V2 Digital Camera
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
