Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon Powershot SD750 powers up fine; lens extends fine. The LCD is black. I can see a faint image - enough to enter the menu and change settings. Increasing brightness has no effect. Seems like the screen has gone bad. Any suggestions??
  • Canon Master
  • 4,738 Answers
It's not the screen, but its backlight that is the problem. It's likely a poor connection of the ribbon cable in its connector socket. This problem will require either professional repair, or your opening the case to reseat the backlight ribbon cable in its connector. Here's a disassembly of a somewhat similar SD600 to give you an idea of what's involved.
Posted on Sep 28, 2010
My canon ixus70 will not take photos,I can view past photos but it will not show image on screen or record digital image ,if I take a shot all I get is a black nothing. Janis jvdzelde@bigpond.com
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd750resetscreen.gif 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd750resetscreen.gif 4. Select [OK] and press funcseticon.gif.
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Jul 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon SD 750 all images blurry on left side
service the focousing unit of the lens,if needs replace the unit.
Apr 02, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error restart camera I have a point and shoot canon sd750; the lens will not retract and i cannot take any photos nor view photos
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 30, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black Screen on Canon PowerShot SD750
Probably bad CCD. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Sep 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error restart camera SD750
somebody saying under warranty
http://www.digitalcamera-hq.com/digital-cameras/canon-powershot-a570is_question.html?qid=12688
May 30, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Turn on camera but the lcd sceen is black
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!! Contacted Canon prior to this and they had no idea but suggested I send it in to be repaired at a cose of $163.50 Australian. Pleasant staff they have, but no help in solving what looks like a common problem of Canon cameras. I will have second thoughts purchasing Canon from here on in.
Mar 23, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
If purchased less than 30 days ago, take it back to the store for a replacement. If the store can't help you, Canon should then help you under your warranty. If Canon won't help, try these as a last resort:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Unfocused
Take it back to whoever TRIED to fix it.
Dec 26, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
235 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
