Question about Maytag LAT3600A Top Load Washer
Remove top - Maytag LAT3600A Top Load Washer
  • 205 Answers
Hello- You will actually need to remove the front in order to access the 2 screws holding down the top. Unplug the machine before doing any disassembly. To remove the front panel there are 2 screws located near the bottom of the panel on each side. They are hidden by the bevel on the panel and located under where the panel angels in about 4" from the bottom. Look under that bevel and you will see the screws. Remove these and pull the bottom of the front panel towards you and up, the panel will hinge from the top and once you get the bottom up high enough it will drop free of the top. To hinge loosen the top there are 2 bolts located under the top where the side of the cabinets meet the front of the top panel. Once these are removed the top hinges up and back. There is a hose, tube, that comes from the bleach dispenser that you need to pull off from the bottom of the dispenser, there is usual no clamp on this at the top (you will see it on the front right side when you pull the front off). Hope this helps, best regards.
Posted on Sep 28, 2010
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
How do I remove the top on a Maytag range
Unplug the range from power.
Open the oven door. Look on the right and left sides of the oven frame just below the top. Remove the 2 screws. Pull the top forward. Remove the wiring harness connector at the back.Lift the top up and off. Set the top aside.
Nov 11, 2009 | Maytag MER5775Q Electric Kitchen Range
Removing the washer top to replace the washerplate
DO YOU HAVE AN EMBLEM IN THE MIDDLE AT THE TOP OF THE FRONT CABINET? IF SO THAT IS THE EMBLEM YOU REMOVE. TAKE A PIC AND EMAIL IT TO ME A GOOD CLOSE UP BUT NOT TOO CLOSE OK. I LOOKED AT THE PIC ON YOUR REQUEST BUT THAT DOES NOT MEAN THAT IS WHAT YOU HAVE.
Apr 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
ROVER MGF.REMOVING WIPER MECHANISM.
Pivot Shafts and Linkage
The windshield wiper assembly is mounted below cowl top extension (021A36) . Linkages are connected with non-removable plastic ball joints. Windshield wiper mounting arm and pivot shafts are an integral part of the windshield wiper and are serviced as one unit. Removal
  1. Disconnect the battery ground cable (14301). Refer to Section 14-01 .
  1. Remove antenna mast from the antenna base.
  1. Remove cap on LH and RH windshield wiper pivot arms to expose nuts retaining the arms to pivot shafts.
  1. Remove two nuts, one from each of windshield wiper pivot arms . Lift wiper arms to service position, carefully rocking them back and forth to loosen them from the pivot shaft. Lift off windshield wiper pivot arms .
  1. Remove seven screws retaining the cowl top vent panel.
  1. Disconnect windshield washer hose (17A605) at LH side of vehicle just ahead of where it enters cowl top.
  1. Remove hood cowl seal.
  1. Carefully remove cowl top vent panel from vehicle.
  1. Remove three retaining screws to cowl drain tube that is connected to top cowl.
  1. Disconnect wiring harness leading to windshield wiper motor.
  1. Remove five screws retaining cowl top to vehicle and remove cowl top and windshield wiper from vehicle.
  1. Remove two screws and two nuts retaining windshield wiper to cowl top and separate the two parts.
  1. Remove drive linkage from motor shaft linkage.
  1. Remove remaining screws attaching windshield wiper and separate the two parts.
Item Part Number Description 1 02010 Cowl Top Panel 2 N621906-S2 Nut (2 Req'd) 3 17508 Windshield Wiper Motor 4 N805605-S36 Screw (2 Req'd) 5 17500 Windshield Wiper Assembly A — Tighten to 9-12 Nm (80-106 Lb-In)
Feb 23, 2009 | 1998 Ford Windstar
89 ford mustang convertible
This is a professional job for a conv. top shop. has to be sewn in at the bottom.
Removal
NOTE: Mark vinyl to be removed so it can be returned to the same position after disassembly.
  1. Remove sail area panels as outlined.
  1. Remove staples retaining elastic straps at each side of back window glass (42006) to rear tacking strip and folding top rear number 4 bow (51278) and remove elastic straps.
  1. Remove staples retaining rear bow corner pad (537A71) and bottom of folding top back window curtain (52500) to rear tacking strips.
  1. Remove staples retaining top of folding top back window curtain to folding top rear number 4 bow and remove back window glass .
1994 mustang. don't have 89 Window, Rear Installation
NOTE: Transfer markings from the removed assembly.
  1. Mark with grease pencil center point on folding top rear number 4 bow in line with hole on rear of folding top rear number 4 bow .
Oct 07, 2008 | 1989 Ford Mustang
Maytag md 4000 dryer, removing the top?
hi thanks for the question .2 screws at the bottom of front panel remove remove front 2 3/8 screws under the top at front remove & lift top .thaks the appliance doc
Sep 28, 2008 | Dryers
NEED TO REMOVE THE DOORS
Normally doors on refrigerators are removed beginning with or at the top. There may be a cover over the top hinge which can be popped off to expose the screws or hex head bolts that hold it in place. Once the top hinge is removed the top door can be lifted up and removed. Next remove the top hinge of the bottom door, lift the door to remove. Finally remove the bottom hinge. Place all parts in a secure place so they do not become lost. Re-assembly is in the reverse order.
Jun 01, 2008 | KitchenAid Refrigerators
I am trying to remove the inner drum
The top panel?? Remove the screws at the bottom front. Pull the front panel out from the bottom while releasing the clips on top. remove the screws in the corners under the front of the top panel and swing the top up.3bceb93.jpg
Jan 06, 2008 | Washing Machines
Maytag LAT3600A Top Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
