Question about Lionel Trains Classic Freight Train Set
In an owner's manual for Lionel's item # 6-38616 Pennsylvania Mikado Jr. Locomotive and Tender. I am trying to find the program button and also the sound button. The locomotive runs fine, but no sound.
3 Suggested Answers
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
SOURCE: i have a lionel gg1loco.the
Is this the manual you are looking for? http://www.lionel.com/media/servicedocuments/6204738521250GG1.pdf
If not please visit the link below: http://www.lionel.com/CustomerService/service-documents/ type in the search box the product name or number..
Posted on Aug 31, 2011
I have a Lionel 7796 New York Central. The remote blinks a constant red and it does not operate the locomotive.I thought it was the remote so Lionel sent me a new remote but the same problem exists.
The locomotive is not receiving the single from the remote . You need to paire them. In the Manuel should be intuitions for pairing. Hope this is some help.
REDEAGLE
Dec 17, 2017 | Crafts & Hobbies
I have a new 104 MTH Long Island engine and tender and I cannot get it to run.
The locomotive may be defective as received. Try applying power directly to it to confirm.
Dec 05, 2016 | Crafts & Hobbies
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
http://www.lionel.com/ContactUs/
Dec 22, 2012 | Toys
How to add water
Here's a link to Lionel Service Documents,,Owners Manual for you train.
http://www.lionel.com/media/servicedocuments/71-0018-250.pdf
Dec 02, 2012 | Lionel 6-30018 Pennsylvania Flyer Steam...
Instruction manual
Search the Internet, you may find a PDF file containing the manual. If all else fails, contact Lionel and request a manual.
Dec 08, 2011 | Lionel 'o/o27' 1645 4-4-2 Pennsylvania...
My train wont go in reverse
Try flipping the "Reverse" switch on the bottom rear of the locomotive.
Jan 03, 2011 | Lionel Pennsylvania Flyer Train Set
Our Lionel Holiday Tradition Express Set 7-11102 will not move even though all of the other functions work properly
Did you check the reverse switch? Be sure that it is turned ON. If your locomotive still will not run, check that there are no fibers wrapped around the wheel axles or any exposed gears. If none of these fix the problem you will need to take your locomotive and tender to a Lionel Service Station.
Dec 21, 2010 | Toys
I have a Lionel 2055 post war train that I have not used in many years. I am setting it up around the Xmas tree. It ran well on the carpet when I tested it out but not around the tree on the hardwood...
Check to see if you picked up any fibers on the wheels or axles from your carpet running. Also check to be sure the pilot truck can swing freely from side to side and is not bent. There is also a light coil spring on the front truck pivot pin. Be sure that the spring is there and is not damaged. Another thing to check is the drawbar between the locomotive and tender. Your front wheels may be getting lifted off the track because the rear of the locomotive is getting pressed down. This a soft carpet may compensate for this but not a hard surface. Run your train at a speed where it derails and look closely at the locomotive to see if the rear is being pressed down.
May 23, 2017 | Lionel Toys
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Lionel Trains Classic Freight Train Set Logo
152 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
