Question about Protron Televison & Video
My tv is in invald mold i cant get picture - Protron Televison & Video
  • 10,594 Answers
I need model number of your tv and details about problem to diagnose possible cause.
Does tv show invalid message in all inputs?
Thanks.
Posted on Sep 28, 2010
My samsung e 2222 cant install app its write jar or jad are invald
could be the application who need to installed not good or missing some files
or your system have a gabs then you must restore your system
Jul 16, 2014 | Cell Phones
Trying to determine if this is mold
Put some bleach on the spots. If they turn brown or disappear, then it is mold.
Dec 25, 2013 | Heating & Cooling
I have a 2000 Mazda 626 4cyl 2.0 liter DOHC engine replacing the timing belt, what are the correct timing marks position on both cam shafts with #1 piston at TDC
I cant find a picture to show you, but if you rotate the engine until #1 is at TDC there should be a timing mark on the crankshaft gear that lines up with a pointer and the cams should have marks that line up also. Most of the time there is a molded line in the cam gear and it lines up with a molded slot in the plate behind the gear at the 12 O'clock position.
Jun 05, 2011 | Mazda 626 Cars & Trucks
I have an old att sim card in my phone and when i turn it on it says invald sim and i cant get wifi
You should be able to bypass that screen, but that will depend on the handset. You can goto att.com/wireless and select wireless, then support, then select your device, and use the tutorials if you are unable to get past that screen,
Mar 27, 2011 | Cell Phones
I cant find where to put second memory card in my esystem el3102 laptop
With most newer laptops, 1 memory slot is located under the keyboard and 1 is located somewhere on the bottom of the laptop. The one on the bottom is usually marked with some kind of picture stamped into the plastic molding.
Oct 15, 2010 | Computers & Internet
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
Aug 03, 2010 | Sansui Televison & Video
Picture is curved and wording is overlaping on my Sony 65'' hd pro
convergece ic's are bad also check low value resistors on convergence board. not an easy repair. you need expert soldering experience.
Feb 25, 2009 | Televison & Video
LG KU990 -Invalid Access to Memory Location
I had the same problem and thanks to another user on the website I have now fixed mine.
Unistall everything to do with LG on your computer and disconnect your phone. Start from scratch and install everything again.
It worked for me and took about 10 minutes.
Good Luck
Jan 01, 2009 | LG KU990 Viewty
Need to fix the color and screen
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60 inch projection tv
you can ask a good tv Technion man, since if it happens to be like that then in coming day u will have to face problems. So since this very common problem which will arise in old tv. Actually the real problem is that, some parts in the board may have become weak or the molded part in the board may have fallen down ,so changing that particular part or molding again may fix that problem. Since i am not an Technion I don't the right terms to help u.I have see this problem in many places and don't worry your picture tube is well and good.
Aug 10, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
