Question about Redfield Binoculars Aurora Water Proof Black 10x50
I am trying to tighten them up. they are very loose
The chain has come off. I put it back but it is too loose. How do I tighten it
Should be a screw next to the bar. you can tighten it and it will tighten the chain. Keep in mind that the 2 bolts holding the bar and cover in place have to be loose to do this.
May 27, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Guitar tuning peg seems like it might be broken it will tighten the string to a certain point then it clicks and its completely loose again...I'm new to guitar so I don't know If this is normal
It seems like you wound and tightened your string on the tuning peg loosley. Try wounding the string at least 4-5 times around the peg after you pass the wire though it and then after winding pass it through the hole again. Tighten well.
If that doesn't work your peg might be broken, but looking at it on the video seems that it's not, even though you can't see it clearly.
Try tightening the screws on the peg, since there's a lot of tension on the highest string and it might cause the peg to click back because the tension is too high and it's loose.
Jan 30, 2013 | Music
Loose Carburator
If the carb mounting screws are tight then it is likely that the entire cylinder assembly is loose ( this is common) and the cylinder to crankcase screws need to be loc-tited and tightened.
If the carb mounting screws just spin and dont tighten then they are stripped. The intake block is plastic so you can either try over sized screws ( first try a screw that is the same diameter but a bit longer) or replace the intake block.
Nov 11, 2012 | Homelite Garden
How do tighten the timing belt on a 2005 pontiac grand prix ?
replace the timing belt tensioner if belt or chain still loose.
May 30, 2009 | 2005 Pontiac Grand Prix
Loose Oven door handle
Ok you need to use plastic or rubber washers against the glass so it doesn't break. To stop the handle comming loose again you need to put "Lock Tight" on the screw threads then tighten carefully only untill the handle isn't loose. You can get this from any good hardware store. cheers
Please give feedback
Mar 23, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Head space loose on Peugeot bicycle
Sometimes the topnut works loose enough for the adjusting nut to come loose and then everything is loose. What usually happens though is that the bearings in the cages wear into the cups and you need a new headset. They come in various sizes and types so you will either have to take the bike in or take all the parts from your headset in to get a replacement. You should try backing the topnut off some more and then tightening the adjusting nut down as much as you need to remove the play and still not have any friction while your steering and then tighten the topnut back down. It will require a thin walled bicycle wrench the correct size to hold the adjusting nut in position so that you don't tighten it further while you are tightening the topnut with a second suitably sized wrench. Hope this helps.
Mar 08, 2009 | Cycling
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Optics Logo
Top Redfield Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Redfield Optic Expert? Answer questions, earn points and help others
