Question about Linksys Wireless-G WRT54G Router
I cannot access a connection to the Linksys with my Kindle. What do I do now? -- Thank you!
Unable to access internet after connecting to network with kindle. Password was inserted.
Are all other devices able to access the internet through WiFi? If so, I'd reboot the Kindle and connect again. Check its network settings after it appears to connect to your wireless router and double check what IP address it is getting from your router. If you have a valid IP address on your Kindle then try to follow the instructions on this link and see if any of them help:
https://www.amazon.com/gp/help/customer/display.html?nodeId=201730640
Aug 31, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
WRT120N ROUTER TO KINDLE FIRE
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 29, 2012 | Linksys WRT120N Wireless Router
Cannot connect
What error do you get?
How many wireless computers and devices do you have in the network?
Can you access wireless network on other computers and devices?
See how to connect kindle to wifi
Jan 18, 2012 | Linksys Wireless-G WRT54G Router
Need username & password for my E1000
First check the wireless settings of your router. You will find all the wireless settings under the wireless tab.
For this you will need to access the setup page of the router by entering 192.168.1.1.
Dec 31, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Trying to establish a Wifi connection for my ereader. I am no longer sure of my password and need the company password according to my ebook instructions. Can you help?
You can reset the Linksys back to the default settings by -
Power up the
Linksys and press and hold the pinhole RESET button at the back of the Linksys for approx. 30 secs until the router reboots, then release the RESET button.
Connect a LAN cable from the LAN port on your computer to the
Linksys router. Open a browser and enter the Linksys' configuration URL.
http://192.168.1.1
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 21, 2011 | Linksys Wireless-G WRT54G Router
I have Kindle 3 WiFi and cannot connect to my Linksys WRT54GS in my home. How do I change the setting to allow MAC access? Thanks!
Hi, the MAC address filtering settings can be accessed by logging into your router's configuration software (type 192.168.1.1 into your web browser and hit Enter, then type in your username and password) and going to the Wireless tab and beneath that, Wireless MAC Filter. You can either choose Disable to turn the MAC filter off completely, or you can choose Edit MAC Filter List and add your Kindle's MAC address to the list of approved devices.
Jan 19, 2011 | Amazon Kindle 3G
Kindle 3rd Generation -- Linksys WRT54G router. Kindle won't recognize password set in router -- Always says "Unable to connect to Wi-Fi Network. Would you like to enter the passworsd again or...
I don't have a solution -- I'm having the exact same problem and I'm looking for a solution. Called Kindle tech support, and all they could recommend was to go to McDonald's to see if I can connect using their wireless. They DID say this Linksys WRT54G router is a compatible router with the 3rd Gen Kindle.
Jan 12, 2011 | Linksys Wireless-G WRT54G Router
I cannot access the router with a kindle when I tipe my password in the kindle it tells me its the wrong password when it is the right one
It may want a WEP key rather than a password! Thats what my kindle uses for WiFi.
On a linksys router you can usually find this by using a browser from a computer attached to that network.
Typically you will type in 192.168.1.1 as the address of the router. (Sometimes that will be 192.168.0.1 or 192.168.2.1)
When you see the router home page, login and view the wireless settings. This is where you will find the security key you need.
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
I have a Kindle (wifi version) and can't connect to my network. I have a wrt54g linksys router. do i enter my router password or my wpa shared key? I've entered my router password many times and it...
You have to enter the WPA share key. The router password is only to access the built in administration web facility. The WPA share key is the encryption key necessary for the Kindle to connect to your router.
Jan 02, 2011 | Amazon Kindle Wireless Reading Device
Kindle won't connect with Linksys WRT600N router?
There might be the issue with the ip of the router.You need to reset the Kindle Device and router as well. You can ask to the amazon for Kindle support Kindle Technical Support Registration 877 690 9305
Nov 06, 2010 | Linksys WRT600N Wireless Router
Linksys Wireless-G WRT54G Router Logo
1,448 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
