Question about Hisense Televison & Video
I have a 42" Hisense television with an EN21660A remote. The remote works but Channels must be input manually. The channel up/down does not work. Any help would be appreciated
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
SparkGap
  • 363 Answers
SOURCE: TUNING IN A TELEVISION
Please could you provide a Manufacturers name and the model of TV. One of us might be able to find a manual for you. Cheers.
Posted on Sep 28, 2007
  • 87 Answers
SOURCE: Tv not changing channels.
This likely has a bad main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
HDTV GURU
  • 261 Answers
SOURCE: Can't advance channels with remote
UNPLUG cable settop box and reset...Then go from there. Let me know and good luck.. GURU JAY
Posted on Feb 06, 2008
  • 6 Answers
SOURCE: video issues
On a Z42PX2DA this symptom is a possible Y Sustain board failure.
Posted on May 09, 2008
How to turn off CC on hisense tv
It might be your Dish remote. There are red, green, yellow, and blue buttons right above the middle of the dish remote. Try pushing the green one. It should let you toggle between cc on or off.
Jul 03, 2012 | Hisense TA42P40M 42 in. Plasma Television
I have a new 32
can you reset to factory settings ?
Dec 31, 2011 | Hisense LHD3204US 32 in. LCD HDTV
Trying to hookup a toshiba dvd player to rca jacks, what mode do i Need to be in on the TV to get it to play? I tried composite video and on the AIR and CATV channels 2-6 to see if that would work but no...
Try website like Remotes.com to buy an original remote.Than try remote input button like 1,2,3 should be in one of it inputs .This is a digital tv,will not work on channels.
Dec 30, 2010 | American Dynamics ADMNPLASMA42 42 in....
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Cannot set my toshiba television to the input channel manually
if you go to channel 2 then channel down the channels between it and the highest are your input channels hope this helps
Apr 14, 2010 | Toshiba 36A40 36" TV
Not getting cable signal.
TRY CHANGING YOUR INPUT SOURCE ON THE MENU FROM AIR OR ANTENNA TO CABLE.
Dec 11, 2009 | Hisense TA42P-HDRA Television
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Aug 04, 2008 | Hisense TL-3220 Television
Televison & Video Logo
123 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
