Question about HP Officejet 5610 All-In-One InkJet Printer
How do you enlarge a document from an HP printer once you have scanned it.
How do I enlarge item in printer once I have scanned it
Posted on Mar 31, 2011
I don't know how to scan and save in forlder, to be able to send them through e-mail. The printer was given to me without the manuel
The printer was given without a manual because Hp has all of a sudden decided to go green.
anyway if you look on your desktop you will see and icon called the hp solution centre.
Bear in mind that you will only see this software once you have installed the software with the disc that came to you.
Place a document on the scanner glass of your printer face down.
Open the solution centre and you'll have a button called scan picture or scan document click on whichever you want and then select the type of file you want the picture or document scanned as.
once done click on the ok button and the scanning will start.
If you need to scan another picture click on finish and the folder will popup where the scanned file is saved.
If you need to scan another picture or document into the same file at the top you have an option on the scanning window saying add another page click on that, once all the pics or documents are done click on finish and the folder to where the scanned files are saved will open up.
by default the scanning path for WINDOWS XP is in my documents under the folder called my scans.
in WINDOWS VISTA AND WINDOWS 7THE SCANNING PATH IS DOCUMENTS AND THEN A FOLDER CALLED MY SCANS
tell ya what copy and paste the links below and follow the steps and would appreciate four stars if you think I am helpful :)
FOR WINDOWS THE LINK IS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02459304&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For Mac OS the link is
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01910186&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 03, 2011 | HP OfficeJet J4580 All-In-One Laser...
How can I scan a document, enlarge the print and send it as an attachment to an email?
Generally, when you scan a document, it is a photo of the item. You can use a photo editor to enlarge then save the enlargement, once done, file, send to, email recipient, this should attach the scan as an attachment
Oct 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I need to scan and email a photo. How do I do that? hp officejet 4580
  1. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  2. Close the printer's document lid slowly so the document does not shift position.
  3. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  4. Push the scan button. You may have to do this on the printer itself or on your computer.
  5. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  6. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
  7. Accept the scan and save. Return the original document to a safe location.
Oct 03, 2010 | Computers & Internet
How do I scan and save to my computer
Dear Sir,
plz follow this step to solved your problem,
1.
Turn on your all-in-one printer and computer. Check the connections between the two machines.
  • Step 2 Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  • Step 3 Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  • Step 4 Close the printer's document lid slowly so the document does not shift position.
  • Step 5 Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  • Step 6 Push the scan button. You may have to do this on the printer itself or on your computer.
  • Step 7 Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  • Step 8 Edit the image as it appears on your computer if you want to make changes. Your scanning softwaremag-glass_10x10.gif might let you enlarge, resize or otherwise manipulate the final product.
  • Step 9 Accept the scan and save. Return the original document to a safe location.
  • Thanks For Your Time,
    Apr 08, 2010 | HP Photosmart C6280 Printer
    How do i scan documents so i can email them ?
    How to Scan a Document on an All-in-One Printer Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
    1. 1)Turn on your all-in-one printer and computer. Check the connections between the two machines.2)Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.3)Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.4)Close the printer's document lid slowly so the document does not shift position.5)Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.6)Push the scan button. You may have to do this on the printer itself or on your computer.7)Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.8)Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.9)Accept the scan and save. Return the original document to a safe location.10) once the document is scanned and saved you can email it.
    2. This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
    Mar 18, 2010 | HP OfficeJet 7310 All-In-One InkJet...
    My hp psc will not scan an object everything else seems to work how do i fix it
    Double Click on HP Solution Center icon to open. The HP icon will be on your desktop or in your start menu. It is the icon that materializes after you use the CD to install your HP scanner or multifunction printer. (It may appear slightly different depending on the model and type of HP scanner or printer).
    Place the document or photo on the glass platen in the proper corner. There is an arrow that illustrates proper placement in HP scanners and printers.
    Click the settings button on the bottom of the HP Solution center screen. It appears as a wrench. This will assist in setting up your scanner or all-in-one HP printer to scan at the touch of a button. Follow the on-screen prompts for photos and documents. Then, scan by clicking the Scan Picture or Scan Document button as appropriate.
    Select the proper choice once you scan, such as save to file (specify where) or email (You also can set up a folder ahead of time so you know where to find the document or photos once they are scanned). Often times the computer will create a default my scans folder and organize them by saving them by date and month scan.
    Click scan and then wait for box to appear. You will see the document or photo being saved and the blue bar will display progress in the HP screen.
    Save the file if the HP software has not already done this for you. Put it in a folder you create and give it a name you will remember.
    Then click "Save"to finalize it. The document should be in the folder that you designated.
    Repeat the process for multiple pages. Keep the HP Solution Center screen open until your scans are finished.
    Mar 09, 2010 | HP PSC 2210 All-In-One InkJet Printer
    HP DESKJET F380 ALL IN ONE
    1. turn on your all-in-one printer and computer. Check the connections between the two machines.
    2. Step 2 Lift the printer’s document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
    3. Step 3 Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
    4. Step 4 Close the printer’s document lid slowly so the document does not shift position.
    5. Step 5 Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
    6. Step 6 Push the scan button. You may have to do this on the printer itself or on your computer.
    7. Step 7 Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
    8. Step 8 Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
    9. Step 9 Accept the scan and save. Return the original document to a safe location.
    Nov 14, 2009 | Epson CX8400 All-In-One InkJet Printer
    How do i scan a document and then email it
    If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
    Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
    Scans are enlarged after switching to vista 64bit
    hmmm... just the set pixels properties to medium..maybe the pixels properties is to high..it can cause long time scanning and large images results ..thank you
    May 15, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
    HP Officejet 5610 All-In-One InkJet Printer Logo
    88 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
