Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Door not opening
My left cd door not opening when i push the open button on my cd mix2
  • Anonymous Mar 25, 2009
    How do you change the drive? Where do I purchase one?
Change the drive, the drive is known to have problems and you should be fine
Posted on Jun 15, 2008
1998 Toyota Corolla CSI Seca. i was trying to replace the light on the roof. while doing this i noticed the CD player and door open indicators are not working. i have replaced the fuse for CD player.
iF YOU HAVE AN CAR ALARM TRY RESETTING, YOUR CAR ALARM RESET BUTTON AND SWITCH ARE NORMALLY DRIVERS SIDE AT THE LEFT KICK PANEL FLIP SWITCH THEN PUSH BUTTON UNTIL YOU HEAR A COUPLE CLICKS. I HOPE THIS IS HELPFUL.
Oct 21, 2014 | 1998 Toyota Corolla
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Open disc drive door
There's a button in the center of the CD tray you must push to get it open with the notebook powered on. If you need to open the door without power on then push a paper clip in the tiny hole on the CD door to release it.
Feb 21, 2014 | Dell INSPIRON 15 Notebook
Left drawer is not opening when pressing eject
Bad mechanism or probably switch. Take to shop. Peace.
Feb 20, 2014 | Numark iCDMIX2 Dual CD & iPod Dock DJ 3 Ch...
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Cassette door will not open
below the push button their is a tiny whole , take a needle of about 3---4 inches in length and insert in that whole and your door will slightly comes out then open it with your fingers
Jun 14, 2010 | Audio Players & Recorders
CD "door" will not open.
Push a paper clip inside the hole in front off the drive to open it manually
Apr 05, 2010 | IBM NetVista PC Desktop
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
My CD Drive Is Not Opening & Not Showing To The My Computer =(
if when you push the button its led flash but not opening, turn off your computer and open its door by a needle enter and push it in the ole in center of its panel under the door. whon the door open a little use your hand and open it. if the this not solve the problem there is a hardware problem :( But if the drive dosent work at all (even the led light) maybe it's the power, then open th case left door and check th power cable... I hope this helps...
Nov 02, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
404 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
