Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
Heater wont come on. pool side of temperature control failed about 2 years ago. now I'm thinking the spa side failed and need to replace the temp control unit. Is this a logical assumption? I'm a handy guy and can replace myself. is here a way to test with a volt ohm meter to make sure b4 i buy a new one
  • 44 Answers
The most common problems with these heaters are the control board, and the pressure switch. The pressure switch is much cheaper,and easier to replace.Try jumping the switch first(but don't leave it that way). Also be sure the line isn't clogged by turning the pump on for a second while the switch is removed. You should get a steady stream of water. Electronic parts are usually not returnable, so exhaust all other options first.
Posted on Sep 28, 2010
MasterTemp 200 cycles every 30 seconds
since you already replaced the thermisto next would be the control board
Apr 18, 2014 | Pentair Pool & Spa
Laars Lite 2 Pool Heater max temperature too low
if hooked to a system increase temp if not try new temp sensor in heater
May 04, 2013 | Jandy Heater Temperature Control Assembly...
Laars lx 250 not displaying water temp
check the 2 black wires going int the top of the control board if ok need new temp sensor
Oct 02, 2012 | Jandy Laars Lx 250,000 Btu Heater
I have a Pentair Mastertemp 400. It worked fine for 3 years until the temp sensor went out and both (internal and external) were replaced about a year ago. It then worked fine for about another 7-8...
You might have a much bigger issue than the temp sensor. When the heater is running hold the "pool" or the "spa" button for 12 seconds. This will show the exhaust temp, if the temp is rising above 375 degrees with in 1-2 mins then your not getting the heat out of the heat exchanger.
One other thing to check would be an external by-pass. If you have an external by-pass make sure the by-pass is set correctly. Opened or closed to much can cause the problem your having.
Mar 04, 2017 | Pentair MasterTemp 400000 BTU Pool and Spa...
Have a 3.5 year old Jandy Aqualink RS 4 --- the air temp is reading correctly (78 F) but the pool temp is reading (201 F). What could this issue be? Pool sensor gone bad? If so, how do I repair or replace...
It is most likely not a bad reading on the on the display.
One culprit of a false temp reading could be:
If the temperature sensor is installed after the heater and the circulation pump is clogged or failing, this would allow super heated water to reach the temperature sensor and give you that reading. However, most pool/spa heaters have a high limit switch that would shut down the heater @ 150 degrees F. So this is also unlikely.
The most reasonable answer is to replace the temperature sensor.
If you refer to page 22 in this manual http://www.jandy-downloads.com/pdfs/Allbutton_manual.pdf
you will see that the temperature sensor is installed on terminals 5 and 6.
Trace these wires. They will goto a thermowell (which holds the temperature sensor) either in the pool plumbing, or to a temperature sensor in the heater itself. Temperature sensors when in the heater are located typically above the inlet/outlet header. There will be some disassembling required to access it in this case.
If it is in the heater and you need more help, e-mail me @ adamh@newconceptchem.com
Please take the time to give me a positive rating on this post if I have helped.
Thanks
adam
Nov 02, 2010 | Jandy Pool & Spa
Temperature on the display is not the actual temperature. Heater will not come on
Without more info like what the temp reading is and what the actual temp is it is hard to say. The first thing that comes to mind is temp sensor has gone bad. This is located on the side of the water manifold and the wires run back to the control board. You can order one with a model number from your local pool store. These are very easy to replace I hope this does it.
Sep 05, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Jun 08, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
162 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
