Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Set up menu
I have a sony tv model KV-27FS100 - my problem is that about every 6 months something goes wrong with the chip in the tv and the set up menu keeps flashing on the screen. nothing you do gets rid of it. it will flash off and on by itself and sometimes it stays on the screen for a minute or two and then disappears for a few minutes. then it comes back again.
  • 58 Answers
Check to see if something was spilled on the screen of this set
or using too much cleaning solution.
As it will run down on to the tac switches and create problems with the cpu.
Thanks guy
Posted on May 27, 2008
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
I have a 6 year old(nov 04) Sony KV-30HS420 that turns off all by itself. The screen goes to green and the picture fades to black. The sound will keep playing for a few seconds then the TV will turn itself...
If the screen goes rather bright green it is one of two things:
1. It is possible it is a shorted green gun in the picture tube, there are three of them, red, green and blue guns in neck of the tube.
2. The other possible reason is there is a problem on the small circuit board at the end of the picture tube, this model should use three IC chips, one for each red, green and blue.
Being intermittent makes it hard to tell but ask the shop if they tried the self check this set should have. With the set turned off use the original Sony remote and hit Display, 5, vol down, and power.
If the set has a self check (it should) a box will appear on the screen with up to five items with a zero to the right of each, items will be like AKB, OVP, etc, and if any have something other than a zero to the right it pinpoints what happened.
Sets with this feature record each event where something goes wrong, ANYTHING other than a 0 indicates what failure was detected.
If I was to make a guess there will be a number next to AKB, which is Anti-Kine Bias, this means the picture tube or something on the board at the end of it drew too much current and the set's shut down circuit turned the set off.
I actually fixed one of these where both the blue and red IC chips on that board were bad, needless to say, I replaced all three of them.
Any good shop would know about the self check and even if the set did not shut down in the shop the self check would point to the area where the problem is.
Let me know if you need more help or find a error code.
REGARDS, SD TECH
Dec 01, 2010 | Sony FD Trinitron WEGA KV-30HS420 30" TV
SONY TV MODEL KV-27FS120 stand by light
if it is continous blinking.........then you have a faulty jungle IC IC301,shorted to ground,IK video path is defected,............ hope this helped
Feb 17, 2010 | Sony Televison & Video
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Menu box keeps appearing on the screen
    There are meny reasons this might be happening. here are a few obvious ones.
    1. The remote is under a cushion and buttons are being pushed.
    2. The Sensor on the set is in the sun and the sun is confusing it.
    3. You neighbor is messing with you
    4. The set has a bad chip/loose connection/etc.
    [you might try something as simple as unplugging it for a minute.]
    5. it's set to 'DEMO' mode.
    Ken
    Jan 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Standby mode and can't get tv to work
    This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
    Thanks,
    Dan
    Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
    46 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
