Question about Intertherm P3RA-048K Air Conditioner
Intertherm condensor air conditioner/heat pump
When it calls for A/C or Heat the fan comes on but the compressor doesn't come on for 2-3 minutes. When it finally comes on it runs great.
  • spike627499 Aug 19, 2008
    My blower kicks on and it blows luke warm air and won't kick off. Then, when you push the thermostat up and let it stop and then bring it back down to where it kicks on again, everything runs fine....wonder why??
    Mike
I changed the control board and that solved the problem.
Posted on May 26, 2008
Should the condensor fan come on in heat mode?
It depends on the type of heat. If your air conditioner is a heat pump where it runs in reverse (takes heat from the outside air and pumps it into the house), the condenser fan will run. If heat is auxiliary electric coils, only the inside fan should run.
Nov 01, 2014 | Heating & Cooling
Heat pump problems
Some heat pumps have high and low pressure swiches installed to keep compressor from running when unsafe conditions occur that can damage the compressor. If the outside fan is not turing on, the unit is cycling on high pressure, if you see ice forming on the big refrigerant line coming from the air handler, then the compressor is shutting down on low pressure. Low pressure can be cause by lack of air flow through air handler or from a low refrigerant charge.
Feb 13, 2014 | Intertherm Heating & Cooling
Have an intertherm split system. Outside condenser compressor is starting, can hear freon flowing, but fan motor will not kick in. Gets hot then kicks breaker. Have replaced capacitor with factory part.
If that system is gas heat then you have 2 fan speeds Lo speed for heat and when ac is called for the motor speed shifts to hi with the use of a fan relay.
Some various fan relays in use today. themobilian_2285.jpgthemobilian_2286.jpg
May 02, 2011 | Heating & Cooling
I have an intertherm furnace and the circuit board burnt up...replaced the board and the heat works fine....the a/c condensor comes on on cool but the fan will not come on
If you are talking about the fan motor on the condensor then I would check the start capacitor if it is an older model it should have a seperate capacitor in the elec. connection box for a/c condensor fan and compressor. Thank you.
Mar 07, 2011 | Heating & Cooling
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Sep 30, 2010 | Intertherm P3RA-060K Air Conditioner
No AC from older Intertherm split system
It sounds like you are low on refridgerant. Double check to make sure both fans and the compressor are running. If so then you have a refridgerant problem.
Aug 29, 2009 | Heating & Cooling
Intertherm central unit heating side not working right
I am assuming this is a heat pump? (Typical when the t-stat has a green light.).
Please confirm
If a heat pump, is the outdoor unit frozen up? There can be some frosting, but it should not be a block of ice.
If there is an emergency heat switch on the t-stat, can you flip that to emergency heat? Do you get heat then?
Pleas advise and I can help you troubleshoot this problem further.
Jan 30, 2009 | Intertherm P3RA-060K Air Conditioner
No heat
need to know if its a heat pump or electric strip heat. if its a heat pump then compressor and outdoor fan will run on call for heat. being an intertherm and most of them are electric strips, i'll guess. the call for heat sends 24 volts to the heat sequencer. lots of wires connected to what is called a stack switch. wires closest to the mounting plate are 24 volts and when energized they heat up a bimetal disc that clicks on in 90 to 160 second s and energizes the first strip and fan and a few seconds later the 2nd and 3rd strips kick in. for every strip operating you pull about 20 amps. if fan is working then the other parts of the sequencer are failing to close and put power to the strips or the strips themselves are bad. these are very very confusing and tricky to work with. i have to work on them hot to observe where the problem lies. very dangerous as you are going to have to trip a 90 amp breaker if you make a mistake , not to mention the parts are not available except through wholesale only supply house. i feel pretty confident the sequencer is going to be bad and i think its probably best you call a pro to get this one squared away. sometimes when you are tinkering with old sequencers they literally crumble apart in front of you, they can get that brittle. it can be quite an adventure and not for the faint of heart when its hot. good luck.
Oct 28, 2008 | Intertherm P3RA-036K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
96 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
