Question about Hotpoint Refrigerators
I have water under my vegetable bins and know the defrost drain is probably blocked. How do I clean it out? My model is CTX21DABRRWW
aborcass
  • 2651 Answers
SOURCE: Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Posted on Mar 21, 2008
  • 198 Answers
SOURCE: water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Posted on Jan 27, 2009
  • 297 Answers
SOURCE: water runs under the vegetable bins
There should be a collecting channel with a hole and a tube reaching down to somewhere above the cooling compressor (Back of unit) where it should evaporate with the heat.
Most people never clean that hole and tube simply because they do not know what is for or the manual is silent. Sometime can be jammed with little icecube. I us thick plastic line from toy to clean, electrical wire with copper core not naked is also oke. Do not put wild force. This is the cooler part. The deep freezer part needs defrosting on temporarily basis and for that you need some small low bin to start collecting or keep on mobbing the floor.
Posted on Apr 14, 2009
woodchuck789
  • 4059 Answers
SOURCE: Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
woodchuck789
  • 4059 Answers
SOURCE: I have water puddling up under my Vegetable bins
Yes, Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Oct 04, 2009
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Refrigerator leaking water
You gave no manufacturer name or model number so this is only a guess: If you refrigerator is a self defrosting one, it will periodically, allow ice building up in it to turn to water which naturally drips to the lowest point. Most refrigerators have a drain below the vegetable bins on the bottom. That is probably where the water is coming from. Solutions include putting a shallow baking pan under the bins or under the refrigerator to catch the water, then empty it periodically.
Jan 21, 2013 | Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
WATER COLLECTS UNDER THE VEGETABLE & FRUIT BINS. wHAT IS THE PROBLEM?
It sounds like you have a defrost drain problem, I have put together some instructions on how to clean the drain, follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 08, 2010 | Maytag Refrigerators
Water on shelves
It sounds like the defrost drain is plugged. It is behind the back panel inside the freezer. Either defrost the whole unit, or use hot water to defrost the drain line. Be careful it is located right under coil and the fins are sharp! My knuckles have been cut many a time! Good Luck
Apr 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
There is water collecting at the bottom of the refrigerator under the vegetable bins.
you have a clogged defrost drain located in the freezer,u can shut the refrigerator off with doors open for 24 hours to allow the drain inlet to thaw on its own,if problem reoccurs within 1 week chances are you will need a technician to install a drain heater kit
Nov 27, 2009 | KitchenAid Refrigerators
Sep 21, 2009 | Refrigerators
Water in bottom of "fridge" and in vegetable bins
Hi: I'll assume this is should be a frost free freezer. If so the defrost drain is clogged and the water isn't getting to the evaporator pan. Without knowing the specifics although it sounds like a top freezer. Look for a drain below the evaporator coils. The will be in the back of the freezer behind a panel. Some models have a drain hose behind the ref. Use a strong solution of clorox and water to clean it out. The parts list or diagram of the fridge will help you find the drain. If you don't have it enter your model no. at sears.com parts direct. I hope this helps, Jeff
Jun 02, 2009 | Refrigerators
Water runs under the vegetable bins
Apr 14, 2009 | Magic Chef Refrigerators
Water under vegetable bins, no water in drip pan under refrigerat
Jan 27, 2009 | Kenmore Refrigerators
Refrigerators Logo
67 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
