I just bought my ciss kit then i installed it following from the videos in youtube and installation manual.. but wen i put my printer on the ink light is blinking indicating that the ink is low or the chips are not detected??what should i do?? my printer is Epson tx110.. thank you
  • 240 Answers
Did you buy auto resetting chips for your cartridges with the CISS kit?
Posted on Sep 28, 2010
Purchased the ciss ink system for my epson wf-3540. the ink tubing keeps getting pinched and the ink isn't flowing continuously.
I installed a CISS system in my WF-3640 which is very similar to the 3520. I just leave the top open and put a small piece of white eraser in the slot where the cover peg would go into. That way the printer thinks the top is closed. Yo can print, scan, copy, fax, etc., with the top open.
Oct 05, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
How use epson l800 for sublimation ink
Hi.
There are things that you need to understand when using third party inks on CISS Ready Printers. Epson L800 is built to use inks manufactured by Epson and therefore using other inks than specified will automatically void the manufacturer's warranty on the device.
Sublimation Inks are heat sensitive inks but it can be used to most of the Epson Printers on the market. If your L800 is already running using Dye Inks now, you may need to "flush" the Tanks, Tubes and Print Nozzles to avoid ink clogging. Mixing different types of ink is the most common mistake resulting to printhead clogging and by not flushing, you may as well encounter this. If you can buy a new CISS Tanks and cartridges fitted to L800, you may also want to do so to make flushing easier. You only need to flush the nozzles if you replace the CISS Kit.
Flush using a Syringe with the tube on the part where the needle is supposed to be placed. To flush the nozzle, press the "ink" button on the printer. As the cartridges move to the center, pull the power plug to shut down the device. Remove all the cartridges to expose the nozzles. Move the cartridge holder a to the right enough not to lock it in its terminal. Put a paper towel in the base of the printer and move back the cartridge holder placing it on top of the paper towel.
Fill your syringe with cleaning solution and securely attach the other end of the tube to the nozzle. MAKE SURE YOU DO NOT SPILL cleaning solution to any circuitry in the cartridge holder. Squeeze the syringe slowly to flush out the remaining inks on the printhead. 3 to 5 ml would do the flushing. Repeat the flushing to all of the nozzles. Again, be careful with the circuits.
After flushing, remove the paper towel and clean up the base of the printer.
Load your new (or flushed) CISS Kit into position.
After installation, it is necessary to conduct initial setup to rerun the ink from Tanks to tubes to cartridges and to printhead. After initial setup, a nozzle check and cleaning would also refine the quality of the print.
If you ever encounter ink-clogging on your nozzles again, the flushing will also help you do the trick unless your printhead already ran out.
I hope this helps.
Chow!
Apr 23, 2014 | Ricoh A3 Gel GX7000 InkJet Printer
Unrecognized Cartridge of Canon iP1980 Continuous Ink
Do u c any blinking light??
Well.. it seems like you have e5 error which you need to replace your cartridge....for further use.
C the circuit part on cartridge have problem and there is no other choice execpt replacing..
Sorry about not giving you good answer.
For Canon cartridge, u must unplug the power cords before you pull out cartridge as for the prevention.
If you have problem with CISS, try ROADINK product for your ink refill.
If you use CISS quality is not good as branded one. But for ROADINK refill kit, will help you to get quality printing job.
Check out our youtube video.
Jul 01, 2011 | Canon Office Equipment & Supplies
I have an epson stylus tx115 multifunctional printer with the continuous printing system installed . there is plenty of ink in the printer . A red light is flashing telling that there is not ink , I...
You must reset the cartridges chip. About " there is plenty of ink in the printer " you mean ink leakeage in to printer ? If yes, first thing is to clean the printer ( the ciss is not instaled corectly) and reinstall the ciss. The ink tank of ciss should stay at the same level with the printer.
Dec 31, 2017 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus T21 printer not accepting ink supply system
First of all let cartridge in the printer.... Then press Start.. it will say cartridge not recognised... then remove all cartridge (do not turn off printer).. then wait for 15 minutes...then again put cartridges in head... then press start..start...start..It will recognise on 2 to 3 tries.. Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
Jul 11, 2010 | Epson Office Equipment & Supplies
CISS fitted to epson dx 600 fw, problems?
Until I get more information I'm taking no further action. The video on youtube seems straightforward but at the moment I'm having problems with compatable inks not being compatable.My printer has gone to the Epson repair centre.
Oct 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
Hi! I have the Epson DX4850 All-in-one printer. I just purchased a Continuous ink system for it and tried to install it. I followed the installation manual very carefully and when I had finished installing...
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 25, 2008 | Epson Stylus DX4850 All-In-One InkJet...
Have just installed CISS system on epson R265 printer, I now cannot get inks to re-set so I can use printer. My printer has been useing "compatible inks" so I should not have had any...
I am not sure about the system I believe it is continue ink system, which save time for change ink less.
I have not work with yet. but there is the link ot youtub. and some video how it was done and what the porblem area.
http://www.youtube.com/watch?v=86xPmuMqd3c
please rate, if the answer help you.
thank you
Oct 16, 2008 | Office Equipment & Supplies
221 people viewed this question
k24674
jasbo
jasbo
