Question about Gateway FPD2275W LCD Monitor
Viewsonic VX 1945-wm-3 not detecting iPod Mini 4GB 2nd gen
I have PC:intel 845 GL chipset.
When I connect the monitor with the PC with the USB cable, and power on the viewdock base, i get an error "USB device not recognised" for the iPod connected to the viewdock iPod socket.
Though, all the card readers and 4 usb ports on the viewdock are working.
When i connect the ipod with the iPod cable to 1 of the usb ports on the base, it is detected.
The LED on the base is lit. And the iPod is charging.
The only problem is that i cannot access the iPod from Windows XP.
Kindly Help !!
Regards,
Majid
e-mail: supernova.emjay@gmail.com
  • maj_jaw May 24, 2008
    I mean, the iPod Dock only charges the iPod, it doesn't detect it.
  • Anonymous Jun 10, 2008
    Same issue - the problem is that it has worked in the past, but is not detecting it now...
All,
Ignore the suggestion from kgism397 as Windows XP and Vista include the required USB drivers for and iPod. I was having the same issues mentioned above with the Viewsonic VX2245wm monitor with the iPod docking station. I have a 5th generation iPod. When I used the USB ports on the base of the monitor, (w/ Apple's included USB cable) the iPod was recognized. When I attempted to put the iPod in the docking station, I get the "Device not recognized" error. After a lot of searching and trying out different drivers, I discovered it wasn't a driver issue at all. There is a little plastic guard that sits in the docking station. (there is a different piece for 3rd gen, 4th gen, iPod Nan, etc) Just remove the plastic piece all together, and then set your iPod in the docking station. Apparently the plastic piece was preventing my iPod from making a solid connection with the docking port. Immediately my iPod was recognized and synced up just fine!
Posted on Jul 05, 2008
I have the same problem, and there seems to be no appropriate drivers for this, or at least, none of the drivers I have used work.
Posted on May 26, 2008
  • 105 Answers
USB device not recognised" - means windows needs driver to function. As soon as you connect USB device it check driver in cache it is available it detect smoothly you can perform else it generate errors.
first to instal driver from CD
Posted on May 25, 2008
845 audio
Hi, you can try the auto detection here:
http://support.asus.com/download/Options.aspx?SLanguage=en&type=1
As it probably is an intel driver you can try the function here:
http://www.intel.com/p/en_US/support/detect
Or you can try to search for the full mainboard number
Here is an exampel where you find it:
Hope this will help you.
Aug 14, 2011 | ASUS Intel 845 Chipset P4B (P4B WOA)...
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Need audio driver for intel 845 gl
Download it from here:
http://www.intel.com/support/chipsets/sb/CS-009236.htm
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | EliteGroup P4M800PRO-M478 Motherboard
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Viewsonic monitor not detected after service
If you are running DVI-D(the white connector) then it isn't getting a digital handshake. If you have inspected the connection between the 2 and make sure there is no bent pins inside the connector that it mates with. If you have another computer, try to connect to that one.
Open windows start menu, right click on my computer, then choose properties. Next choose Hardware, then Device manager. Once there, double click on display adapters to see if installed correctly. If good, click Monitors. If good, then your video card driver must need reinstall or update as usual. Also do you have the correct driver for you monitor? How does it react when you uninstall the monitor driver(can you select 32bit and higher resolution in default drivers?
If none of this works, I would suspect that the replaced component failed due to static or faulty components within the electronics.
Is there any other changes to the PC (new video card, updated Directx9.0?)
Hope this helps and let me know if I can be of anymore assistance?
Aug 20, 2008 | ViewSonic Computers & Internet
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Gateway FPD2275W LCD Monitor Logo
551 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
