Question about DeLonghi AD699 Airstream Digital 1500 Watts Toaster Oven with Convection Cooking
Bottom heating element warped then stopped working
    Problem Solver:
  • 11 Answers
Can you get in to replace the element?then do so if you can it is easy just look how it was put in as you take it out to replace it!
Posted on Sep 28, 2010
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
My heating elements are warping and one is cracking, sould I still use it?
Absolutely not! This is a fire hazard! Unplug it now and put it in a box! Please check to see if you are still under warranty. If so, call the company (which is a pain) and let them know the situation. They may be able to send you new elements free. If you are out of warranty, then you may be able to purchase new elements and install them for a reasonable price.
Sep 30, 2012 | Euro-Pro TO251 Convection 6-Slice Toaster...
Cant remove warped top grill element
normally this is quite simple 2 screws hold the element on ..If its warped the you could cut it out with a junior hacksaw....Try not to breath in the dust from same...
Mar 31, 2010 | Toaster Ovens
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
DeLonghi AD699 Airstream Digital 1500 Watts Toaster Oven with Convection Cooking Logo
380 people viewed this question
Top DeLonghi Toaster Ovens Experts
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
