Question about Whirlpool LHW0050PQ Front Load Washer
Error f06 / shows to check wire conections between the drive motor & the motor control unit, & between the [MCU] & the central unit [CCU] .My question is do you have a video clip showing where to locate these items.
    President:
  • 1,430 Answers
No video but these links should point you in the right direction.
http://appliancehelponline.com/washercontrolboard.html
http://appliancehelponline.com/washermotorcontrolboard.html
You can also enter in your model # for diagrams and illustrations of your particular machine. All parts come with installation instructions.
Posted on Sep 28, 2010
I have a 7.5 kg whirlpool front loader that is showing error F06. Can this be fixed
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
see this website
Appliance Repair Forums
Nov 11, 2015 | Whirlpool Washing Machines
Error code F06 and E01
Here is what the F06 code stands for
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Dec 14, 2013 | Whirlpool Duet Steam WFW95HEXW
I have a kenmore he3...it is showing a error f06...Wnat does that mean?
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
Jul 15, 2011 | Washing Machines
My kenmore is showing an f 06 code
F06 is a communication error between the central control circuit board and the motor control circuit board, Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU, check your owners manual, some are covered under warranty for up to 5 yrs.
Jun 19, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine is giving me an error message F06, what does that mean?
F06 is Drive Motor Tachometer Error.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) .
• Check the Drive Motor .
• Check the MCU .
• Check the Wire Harness .
Please read the below link it is an article about this error from one of the senior and best expert here
http://www.fixya.com/support/t2946429-kenmore_elite_he3t_giving_code_f_06
COURTESY:JSROCK
Mar 21, 2010 | Whirlpool Washing Machines
3 year old Whirlpool Duet - F07 error showing up 98% of the time on high spin; 70% of time on medium & low spin. Checked conections between MCU & CCU. Should I buy a new MCU or a new washer?
No do the following:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
If the wiring is definitely OK and the drive motor is OK then the MCU is most likely to be the culprit.
Dec 30, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet Washer shows F 06 and stops.
F06-Drive Motor Tachometer Error
  • Check the MCU
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f06
F06 is a Drive Motor Tachometer Error (Unable to Detect Motor Speed).
Disconnect mains power and unplug unit. Check the wire harness connections between drive motor and Motor Control Unit (MCU), and then between MCU and the Central Control Unit (CCU).
Reconnect mains power and switch the unit on. Check the MCU by looking for operation of the drive motor and check drive motor for cyclic powered rotation. Replace any failed component.
Note: If this failure occurs during high speed spin, the door will be unlocked after three minutes
Oct 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine really loud
hi there,
error f06 means Drive Motor Tachometer Error
for this u may
  • Check the MCU
Dec 10, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool washer duet
F/06
  • Check the MCU
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
