Unit not getting power. Went to park for couple hours. Upon return, unit not working and it's hot here in Fla.
    Habit-Forming:
  • 156 Answers
Check the breaker then go out to the unit and check the fuses. If you don't know how to OHM out the fuses at the condensing unit, just pull them out and got to Home Depot and buy new ones. If it blows them when you turn the unit back on, either you have something that is shorting to ground or you have an issue with the compressor winding or run capacitor.
Posted on Sep 28, 2010
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Outside of crockpot gets very hot and countertop is extremely hot after cooking for a couple of hours
This sounds normal. put the unit on something to protect counter. It is very difficult to heat long term, without the unit becoming quite hot.
May 19, 2011 | Rival 3040-VG 4-Quart
GE side by side ADORA, refer and freezer or not cold, cleaned and unplugged to maybe reset. Unit is 4 years old.
return air ducts from the freezer may be iced up, unplug unit and use a hair dryer to defrost. The ducts will be behind the rear panel, but just let the hot air circulate for a couple of hours to really defrost it
good luck
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
I just purchased an Alesis QS7 on eBay. Upon receiving
The unit needs to be repaired. Since it is a thermal problem, you can likely find the bad part with circuit cooler. See if the volume control affects the loudness of the howl... If it does, probably an op-amp in the preamp before the volume control is sick. If it doesn't affect it, then the output amps are suspect. Also check the power adapter.
Mar 03, 2010 | Alesis Music
Lg dvr lst5402p has stopped working .unit wont turn on and no display etcetc . its been very hot over here in perth 39 degrees c in last couple of days. unit is 3 years old. cheers dave g
strangely after a few hours i gave the power button a final go and it powered up . it hasnt been a problem before so it must have been the heat.
ive moved the unit to a slightly cooler spot .
cheers davo
Dec 13, 2009 | LG Televison & Video
My fridge is not working, the freezer still does, though. Front panel displaying ''Er and FF''
sounds like the return air duct is completely blocked with ice
shut unit off for a couple of hours leave a blow dryer blowing hot in the freezer with the doors open
Oct 09, 2009 | Refrigerators
Power to wii console disrupted
Simply removed the plug from the wall socket (left all other connections intact) and waited 3 mins then replaced the plug into the wall socket. Bingo! Light appeared and pressed the power button on the unit. Very happy to FixYa (cannot recall the member's name) for the solution.
Dec 21, 2008 | Nintendo Wii Fit for Wii
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
