Question about Echo Indigo IO Sound Card
Echo indigo io recording problem
I can't seem to record any thing with my echo indigo io. i plug my mic into the output jack and there is nothing. The playback works fine, however i've never been able to record anything. I just upgraded to driver 7.3 and i have windows XP. HELP!
Dont plug mic into output, it is input
Posted on Oct 30, 2008
1) how to make my amp record....because its not working when i try... 2) do i have to a cord in line 1 and 2??? 3) do i have to plug in the cord in :.....line in or line out??????
You will use microphone with balanced XLR connector into the XLR mic input. Note, the ALpha does NOT have phantom power so you cannot use condenser mics.
A guitar can be plugged into the hi-z instrument 1/4 inch jack on the left front of the unit.
To use the line 1/4 inch inputs you will use BALANCED TRS 1/4 inch cables from your source.for these channels. The level on these needs to be line level.
The line outs are for sending audio out to an amp. There appears to be RCA outputs you can use as well.
I am not sure what you mean by making your "amp record"... An amp PLAYS the audio, usually into a speaker.
If you are trying to play a guitar through your amp AND record, then you will connect your guitar to the Alpha, the amp input will have a cable from say Line 1 OUTPUT and when recording wou will have the echo feature on so your guitar is passed through to the amp.
Jan 09, 2011 | Lexicon Alpha Personal Recording Studio
Output activity showing but no sound.
Virtual outputs? in Echo console The phones output is Analog 1-2 and the line output is Analog 3-4. In the Echo console, you can choose between the Analog 1-2 bus and the Analog 3-4 bus in the upper right hand corner. In the Analog 1-2 bus make sure you have virtual output 3-4 muted. In the Analog 3-4 bus make sure you have the virtual output 1-2 muted. From within your audio application you can now assign your headphones output and your house (line) output. Hope this is some help.
Jul 25, 2007 | Echo Indigo IO Sound Card
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
Need to know how to use mic with dp-01
First you'll need to know if your mic is dynamic or requires phantom power. The DP-01 does not provide phantom power, but the DP-01FX and the DP01-FX/CD units have the option of turning on phantom power for their two XRL mic jacks. The DP-01 simply has 1/4" jacks for mics. Typically if your mic comes with a 1/4" plug it will be dynamic, but that isn't always true.
Plug it into the mic/line jack in the front of the unit and turn up the input volume knob. Then depending on which of the two inputs you used you'll have to press the Assign button (A or B) and then the rec button over one of the tracks and turn up the track fader. You'll also need to insure that the master fader is turned up and you should then be able to see the meters moving when speaking into the mic and hear the output in your headphones.
To record simply press the rec button on the assigned track again (it will light steady) to arm the track for recording and press the play and record together.
Hope this helps.
bd.
Jan 08, 2009 | Tascam DP01 All-In-One Recording Package...
No Sound When Records are recorded to Computer via the Microphone
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
NOT RECORDING WHEN USING MICROPHONE
Is the mike turned on///broken? test the mic to make sure its not the problem! it could also be mic jack!
Dec 17, 2008 | JVC TD-W354 Single Cassette Deck
No recording?
GarageBand on Windows makes your music move everywhere, and now you're able to utilize GarageBand to get Laptop/PC. With live Applications, it makes it effortless to get more pleasure in creating music like DJ by triggering loops and audio effects in real time plus GarageBand free Application allows you to do things that you can never perform on a true instrument. GarageBand For PC Download GarageBand For Windows Mac
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
I can't get it running
What is your computer and operating system, tell me this, and I will get you on your way...
Keep me posted.
Dec 11, 2007 | Echo Indigo Stereo Output Device for...
Output activity showing but NO SOUND!
Windows Vista Home Premium--Up to date This may be the problem. Vista is very much AntiPiracy. If you are ripping or such, Vista will give you grief.
Jul 26, 2007 | Echo Indigo IO Sound Card
Echo Indigo IO Sound Card Logo
192 people viewed this question
Top Echo Computers & Internet Experts
Computer Links
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you an Echo Computer and Internet Expert? Answer questions, earn points and help others
