Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not start gives code dl&f - Whirlpool Duet GHW9150P Front Load Washer
  • rtc11 Jul 04, 2008
    washer will not start, get an f code then dl code
  • RHS-Cheetah Feb 26, 2009
    I have the exact same problem with my Whirlpool Duet GHW9150P Front Load Washer.  When you press the button to start, you hear a faint click, then there is the "DLF".  I called Whirlpool and it is a "door lock failure".  Tomorrow I have a repair person comming out at $48, just to walk in my door.  Who know what it  will cost.  I feel like I'm being held hostage.  I've read other websites that talk about a class action suit.  "Count me in!".
    Problem Solver:
  • 15 Answers
DL code is a door lock failure. If you get an F11 code you will most likely need the main control board.
Posted on Feb 14, 2010
    President:
  • 1,294 Answers
Power off the wall, check to see if the connections to the door lock are tight. Or
Try some WD40 on the door mechanism of machine (not door) & open shut a few times; with the mains off the wall.
Posted on Mar 13, 2009
  • prem mathew Mar 13, 2009
    Get a sledge-hammer to within 2 metres of the washing machine. Then go for the button on the right side "end of cycle" & depress it with your finger for 3 seconds, the control light will come off & I hope you will be able to use your machine.
    PS. Remove the sledge-hammer.
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Posted on Apr 29, 2007
SOURCE: washer DL error
F/DL is indeed a door lock error. I had this on my machine, did a lot of research and getting some idea of how it works. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. I could hear clicking from the CCU on my machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code. I tested the latch and wiring from the CCU - OK. The clicking I heard had to be relay(s) so I figured the problem was relay contact failure. I removed the CCU board, determined which relays were suspect (there are two for lock & unlock). I changed them both and saved myself spending $300 CA on a new CCU. The relays cost just over $2 each. I found replacement relays @ Electro Sonic (www.e-sonic.com; minimum $25 order plus shipping $7.50). Relay made by OMRON part # G5LE-14-DC12 replacment for original G5LE-1-VD 12VDC. I'm not impressed to have to change a $300 CCU because of a $2 relay failure. For me this was worth the try as I have some experience working with circuit boards. The relays would be a quick repair for anyone with similar experience. Hope this helps someone.
Posted on Sep 16, 2007
  • 1028 Answers
SOURCE: error code dl then f
sounds like door lock issue but probably not lock itself remove top (3 screws) along back of top ..at rear of machine is control board ..if you are hearing a clicking noise at time door is supposed to be locking try wiggling connectors on control bd if i remember they are the pink wires if door locks then you have a bad connection on control bd may try wedging something under connector to help hold in place but only true fix is a control bd..good luck
Posted on Jun 10, 2008
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Clicking and F dl error
Error code stands for door lock. May need a new door lock.
Oct 23, 2009 | Kenmore HE3T Washer
DL F signal
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replacing the door lock mech will fix this issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
