Question about SAMTRON 55V 15" CRT Monitor
My samsung syncmaster 794 monitor light is blinking but monitor not get on
  • 33 Answers
If you tested that to another working CPU but the same problem before, i think that monitor has a problem in horizontal section, check the B+ atlaest 175v if is it normal the power supply is ok, check the H.O.T horizontal output transistor, remove or hang the 3 pins then power on the monitor, if the led did not blinking the H.O.T has fault may be leak,open or shorted.
Posted on Sep 30, 2010
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Power light was blinking took a long time to turn on, now power light does not blink or go solid and screen does not work
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com This model is on Monitor repair page #2 We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
Sep 07, 2009 | Samsung SyncMaster 760vTFT Monitor
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Apr 20, 2009 | Samsung SyncMaster 720N Monitor
Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Jun 20, 2007 | Samsung SyncMaster 170 T 17 in. Flat Panel...
SAMTRON 55V 15" CRT Monitor Logo
106 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
