Question about Acer Aspire 3690-2196 Notebook
DEP Acer 3690
Hi When I try to open any computer program I receive a response of DEP with advise to close program. Eventually I can try again and sometimes it will open the program. Is it safe to remove the DEP? Please help. Thanks
  • 458 Answers
Sounds like spyware. Is this a VISTA operating system. The Vista O.S. ask you a question every time you hit a key it seems like. You can turn it off and that will help that problem If it is spyware you can do the following.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Turn the system restore off. System restore keeps everything in restore. Meaning......... If you have spyware or a virus, it will stay in your system. Run Spybot S&D (This program is free and is better than using msconfig as long as you go through the settings and change everything to the highest settings.) Then do the same with Adaware 2008 (sounds stupid to use 2 things for spyware, but one catches what the other one does not.). I have links on my website ( These links go directly to the download so you will not get the run around. You would do good to try a program called Window Washer ( This is a great program that completely cleans anything in your computer that you do not need. It will not clean out anything that you have to have. I have used this for years to clean out my customers computers and have cleaned as much as 3 gigs of trash out. If you contact me I will give you some tools that I have for free that will do a great job on your computer. I have them ready to download and I will give you the link. (
Send me the complete specs of your system and I can help you more. I hope that this helps you. There is no reason the really buy a program for spyware when there are free things to use that work great. Free AVG is a great Antivirus and yes it is also free. It will check your e-mail coming and going. It will also let your friends now that the E-mail does not have a virus. It also has a spyware program that is free. This day and time with all of the spyware out on the net you can never have too many programs for spyware. I would not run all of them at the same time though. Make sure that you do not use your computer during any scan. Defrag is also something to do after you do everything else. Some people will tell you that should not reload your computer. If nothing seems to work then sometimes that is the only good way to get it repaired right. Most of the programs that come pre-installed on a store bought computer is useless and most are even trail software that causes problems when they expire. Let me know if this helps at all. Please rate me if it helps.
Posted on Jun 04, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you try what I told you to do? I will still help you, but you need to tell me what you have done.
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
Aspire 5610-2762 Orbicam not working
Try performing uninstall from control panel, even if the program is corrupted. Then install it again using the recovery disk or downloading it.
hope it can help
Feb 17, 2008 | Acer Aspire 3690-2196 Notebook
How to change Data Execution Prevention (DEP) settings in Windows 7? Data...
How to change<b> Data Execution Prevention (DEP)</b> settings in <b>Windows 7</b>? <br /> <b>Data Execution Prevention (DEP)</b> is a feature that protects our system from viruses and other security threats. The Windows constantly monitors the programs running on our system and closes them if they perform any malicious activity. But sometimes we want a certain program(s) to run even if the<b> Windows alerts</b> us that it is a malicious one. <br /> To change <b>Data Execution Prevention </b>settings in <b>Windows 7</b> follow these simple steps: <br /> 1) Right click on the <b>My Compute</b>r icon on your<b> Desktop </b>and select <b>Properties</b>. <br /> <img src="nonontech_54.jpg" /><br /> <br /> <b>Fig. 1</b> <br /> <br /> 2) The <b>System window</b> opens now. Here click the <b>Advanced system settings</b> link in the left pane as highlighted below: <br /> <img src="nonontech_55.jpg" /><br /> <br /> <b>Fig. 2</b> <br /> 3) The <b>System Properties</b> window opens now. Here click the <b>Settings</b>... button under <b>Performance</b> section under <b>Advanced</b> tab <br /> <img src="nonontech_56.jpg" /><br /> <b><br /></b> <b>Fig. 3</b> <br /> <br /> 4) The <b>Performance Options</b> dialog box opens now. Here select <b>Data Execution Prevention</b> tab and then click on the radio button <b>Turn on DEP for all programs and services except those I select option</b> and click<b> Add </b>button <br /> <img src="nonontech_57.jpg" /><br /> <br /> <b>Fig. 4</b> <br /> <br /> 5) Now select the<b> Executable</b> file (i.e. the .exe file of the program you want to add) that you want to add and click <b>Open</b> button <br /> <img src="nonontech_58.jpg" /><br /> <br /> <b>Fig. 5</b> <br /> <br /> <b><u>Note:</u></b> If you try to add an executable file which cannot be turned off it's <b>DEP</b> feature, then you will receive a warning as shown below. <br /> <img src="nonontech_59.jpg" /><br /> <br /> <br /> <b>Fig. 6</b> <br /> <br /> 6) In the same way, to remove an executable file from the list select that file and click <b>Remove</b> button. <br /> 7) Click<b> Apply</b> and then <b>OK</b> button in the <b>Performance</b> options window <br /> 8) Click <b>OK </b>button in <b>System Properties</b> window <br /> 9) Close <b>System window</b>. <br /> Thanks for reading. <br />
on Jan 28, 2011 | Computers & Internet
Window Vista problem??
If you receive this error message or encounter difficulties when attempting to launch Pro Tools using Windows Vista disabling DEP may solve the problem.
This option disables "Data Execution Prevention", a feature of Windows that can sometimes cause errors. This won’t harm anything, but also isn’t always necessary.
How to Disable DEP:
1. Click "Start"
2. Click "All Programs"
3. Click "Accessories"
4. Right Click on "Command Prompt"
5. Left click on "Run as Administrator"
6. Click the Allow button if it asks you for permission
7. Type or copy and paste this into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOff
8. Hit enter and you should see the confirmation: Operation Completed Successfully
9. Reboot and DEP should be off.
If you would like to re-enable DEP enter the following into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOn
Hit enter and you should see the confirmation: Operation Completed Successfully. After restarting the computer, DEP will be re-enabled.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
Internet Explorere keeps closing down
Data Execution Prevention (DEP) is a security feature that helps prevent damage from viruses and other security threats by monitoring your programs to make sure they use system memory safely.
Here is a link to an excellent article on DEP.
Whie it will show you how to turn DEP on, it will also take you to the control panel that will aloow you to adjust your settings.
Oct 03, 2009 | Computers & Internet
Why do i keep getting DEP error message each time i close IE8 or a tab?
windows xp has DEP ( data execution prevention ) some viruses etc use that sort of technique and from SP2 onwards I believe it was they included it.
Several OSs have no-execute or execute protection. Microsoft has added this as well in SP2 with data execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits. If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question… don’t disable it for your whole system.)
    1. Click Start
    2. Select Control Panel
    3. Select System
    4. Click the Advanced tab
    5. In the Performance region select Settings
    6. Click the Data Execute tab in the dialog box that opens
    7. Select Turn on DEP for all programs and services except for those I select
    8. Click Add.
    9. The open dialog box will open. Browse and select your application.
    10. Click Open
    11. Click Apply
    12. Click Ok
    13. Reboot
May 10, 2009 | Microsoft Internet Explorer 8
mine is a acer 9300 and my can just says"acer orbi cam stopped working::what is wrong with these computers,its been used 3 times_?__and crashed__??
Feb 09, 2008 | Acer Aspire 3690-2196 Notebook
Windows vista closes my program
Why is Windows closing my program? gl_icon_tip.png Applies to all editions of Windows Vista.
Which edition of Windows Vista am I using? Windows might close a program and then notify you if it determines that the program is either a security risk or incompatible with this version of Windows.
When Windows closes a program because of a security risk, it is because some programs might use your computer's random access memory (RAM) in a way that could be exploited by a virus and harm your computer. Data Execution Prevention (DEP), a security feature of Windows, tracks how programs use memory. If DEP finds memory being used incorrectly, DEP will close the program and let you know. If you trust the program, you can add it to an exceptions list so that DEP won't close it, but you should first check with the manufacturer of the program to see if there is an updated, DEP-compatible version available.
When Windows closes a program because of compatibility issues, it is because some programs could damage Windows if you try to run them. If Windows notices that an incompatible program might harm your computer (for example, by damaging important system files), Windows will close the program and notify you. Check with the manufacturer of the program to see if an update is available, or check Problem Reports and Solutions in Control Panel to see if a fix from Microsoft is available.
• Open Problem Reports and Solutions by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking System and Maintenance, and then clicking Problem Reports and Solutions.
If this dont fix the problem......... id re-store the computer with the restore cd that came with your computer. Good Luck hope this gets your computer back up and going.Please dont for get to Vote. Thank You.gl_head_str.png
Dec 11, 2007 | Computers & Internet
Acer Aspire 3690-2196 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
