Good Morning, I am looking for a tech manual for VK 9313-602-4-10 1 1/2" 3 way valve pneumatic 5-10 psi range
    Sergeant:
  • 235 Answers
Who is the maker of the valve?
Posted on Sep 28, 2010
How to reassemble the power switch on model 92504 air compressor
You can try but you can go online and find replacement pressure switches. The piping size is important my old one was1/4 inch, paid about $5-6 dollars on ebay. HF probably won't have part. If there is a model number on the switch body or inside cover that will help you. Al you need is one that the piping is correct and the switch Chas pressure range that you need. It is probably set for 120 psi off and 80 psi one. You can change it
May 16, 2017 | Air Tools & Compressors
Code po301 cylinder no 1 has 80 psi all the other have 180 psi
How could you be lost
You explained it perfectly
The shop did all the correct diagnoses,
seldom see that at all,they did great job
of finding the issue
Dec 11, 2012 | Saturn Cars & Trucks
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
2004 Honda CRV air conditioning stopped blowing cold air. Box Store Auto Repair place said it was the compressor cost $1000. A Motorhead friend said it was either the low pressure switch or the high...
Hi!
If by red lined you mean it went over the 250 psi range??
Assumiing that the answer is yes. This is what I think.
The Hi and Low pressure switches prevent damage to the compressor if the pressure is out of range.
Before going any further, check A/C Relay and fuse.
With the engine off, check pressure on both, Hi and Low. Both gauges must have same reading. It should be between 175-200 psi at about 80 degrees temp., if pressure is over that range, the Hi Pressure switch is preventing the compressor clutch to engage, gas needs to be removed by a qualifying A/C Technician.
If Pressre is between range, and both gauges read the same, start engine and turn compressor on, check gauges, The Low side should read about 38 psi and the Hi side should be between 250/275.psi.
Any more trouble shooting should be performed by a Qualified Tech.
Don't forget to rate this post!! Good Luck!!
Jul 20, 2010 | 2004 Honda CR-V
GAS RANGE CONVERSION TO PROPANE
Try this site for the conversion factor: http://www.onlineconversion.com/pressure.htm . 1 Water Column [inch] = 0.0361 pound/square inch (PSI) (to a reasonable number of significant figures).
I hope this helps.
(However, your stove and tank must be very different than mine. We didn't need to adjust the inlet input for the max PSI, just make sure that the incoming pressure was in the standard range for LP. New stove installed last month after old one suffered a failure of the oven valve.)
Jul 13, 2010 | Sears 61301 Gas Kitchen Range
Why coolant coming through air filter element?
Hi dear,
There problem is loan/unload pneumatic valve not work properly. Please change this pneumatic valve.
Jun 20, 2010 | Ingersoll Rand Stationary Air Cooled...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Oil Pressure Suddenly Reading in High and Low Ranges
either the oil pressure sender is defective or the pressure relief ball valve in the oil pump is sticking, my money would be on the oil pump pressure relief valve ball sticking.
May 27, 2009 | 1998 Dodge Intrepid
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
