Question about Casio Watches
I cant seem to be able to turn on the hourly alarm.
I have a xonix watch that chimes every hour, how do I stop this?
I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
Sep 27, 2010 | Watches
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
c. }}}} = Daily alarm on only
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
TGHK hourly chime, and military time
Go to alarm screen and press light and st/sp at the same time.
Sep 23, 2009 | Watches
How to turn off hourly alarm on Gap Sport watch?
Click reset button (lower right) - this shows you the alarm time as indicated by a large letter 'A' that appears in the display.
Keep holding the reset button and simultaneously press the mode (lower left) button.
This toggles the days of the week at the top of the display.
All days shaded in black means the hourly alarm is on.
All days clear means the hourly alarms is off.
Now, if I could just figure out how to choose the exact days the alarm can be set to ring ... it seems like it is possible.
Aug 16, 2009 | Watches
I cant set the digital time in casio illuminator
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How do i make my watch beep by the hour
Press and hold SET, then press START/STOP. This should turn the chime on. Press it again to turn on the alarm.
Dec 27, 2008 | Timex 1440 Nylon watch
Alarm and hour beep
On your watch ( in the digital area) there has to be a a bell looking design and or a ))) That show that your hourly chime is on. You have to either push two buttons at the same time OR go to the alarm mode on you watch and push any button besides the mode button, one of the buttons should take that little bell or))) off you screen. If this dosn't work, PLEASE let me know and I will research this a little more.Good Luck!!!
Aug 16, 2008 | Kenneth Cole 1213 Wrist Watch
How to turn off the every hour alarm on my casio 593 watch
go to mode menu scroll it and find the alarm mode ,when you see in a display a bell it will alarm every hour but if take the bell display it will not alarm every hour..
Jun 25, 2008 | Casio Watches
How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Jul 12, 2007 | Timex 1440 Sports Aggressor 56014 Wrist...
Watches Logo
32 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
