Question about Panasonic KX-T7731 Corded Phone
I have a Panasonic KX-T7731 phone system and I know most of the buttons: 1: Listen 2: Send a message 3: Change personal options *: Disconnect 7: Erase 9: Save it 4: replay 5: envelope info 6: send copy..... but what I'd like to be able to do is hit a button that sends you to the end of the message so you can delete it instead of listening to the whole message if it's really long. Any body know of a way to do that?
  • 2 more comments
  • info71703 Sep 29, 2010
    rockmeister, thanks for the help, unfortunately none of these worked :( The fwd/dnd button then asked for a code?? and the # button "skipped" the message and the > button didn't do anything. Thank you though!
    Panasonic KX-T7731 telephones:
    I am trying to figure out how to fast forward a message to the end so I can delete it without listening to the entire message.
    I have tried the FWD/DND, # and > buttons to no avail.
    Guru, thank you so much, I won't kill the messenger that sends bad news! :) but bummer!!
    The solution was not helpful to my end needs but it did answer the question and I appreciate that! :)
  • 1,871 Answers
Hello! The KX-T7731 does not have the option to jump to the end of a message...And that is unfortunate...Guru............Saailer
Posted on Sep 29, 2010
    President:
  • 2,047 Answers
Although my unit is a KX-TA624. when i want to go to the end of the message i press the FWD/DND button and it takes me to the end of the message so i can delete it. Dont know if this will work with your unit but it is worth trying. if that doesnt work you can try the # button or the > button on the navigational wheel.
Hope this solution has been helpful?
Posted on Sep 28, 2010
Change auto attendant panasonic t7731
You may download a copy of the quick reference guide at http://www.ask-tsc.com/pdf/KX-T77xx.pdf
The KX-T7731 is just the phone. The auto attendant is controlled by the PBX. To change the message, please consult the manual for the PBX. If you don't have that manual, please reply to this post and specify the model of your PBX.
Mar 24, 2014 | Panasonic KX-T7630 Corded Phone
The caller id is working but how to look back the last caller id number(or caller id log) on the KX-T7731, i am using it with the KX-TA824 system.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
Carl
Sep 08, 2011 | Panasonic KX-T7731 Corded Phone
Hi, I have a Panasonic KX-T7731 and I don't quite understand the vocabulary of the manual. So here is what I am looking for I would like when an oncoming call comes in that the caller can select from...
Manual to what? A 7731 is a Panasonic phone that connects to a Key Service Unit. If your KSU happens to be a TA-824 delivered in the U.S., it has a DISA card built in and the instructions are probably in the OM. There, you record a set of instructions that let the system answer and route the caller by digits dialed. If you're using a different KSU, then you may have the Auto Attendant on a Panasonic Voice Mail system do the messages and routing. That set of instructions will be in the Voice Mail installation guide.
Carl
Jun 02, 2011 | Panasonic KX-T7731 Corded Phone
How do I set up my voice mail or know if I can acquire messages? I have a Panasonic KX-T7731 phone system!
You have a 7731 phone. The phone system could be any one of 18 Panasonic cabinets, but probably a TA series. Voice mail could be a BV, TVx box, or central office based. If CO based, an 824 will listen for the stutter dial tone and light the MW light on a phone. There are instructions to make that work.
So, try editing your question to give a bit more information and it makes it easier to give you an answer.
Carl
Mar 29, 2011 | Panasonic KX-T7731 Corded Phone
I would like to listen to message we have, then change the message to a new one. I would also like to take out some of the assignment callers that I transfer calls to. The quick reference guide I have is...
depending on what system you have here are 2 options for personal messages -
TVM system dial into voicemail (usually 200 or 500) dial 3 1 1 and follow the prompt (the older system is option 5 1 1)
SVM dial *382 your message will be played back to change it dial *381
Button programming
Press PROG
Press BUTTON to store
Press 1
enter extension no of who you want
Press STORE
Nov 13, 2010 | Panasonic KX-T7731 Corded Phone
Simplify the changing of the timeon the Panasonic phone KX-T7731
There are a few types of phone sytems that work with the kxt 7731. these instructions should handle most of them.
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set. 1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming2.gif mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000 4.- Press "SPEAKER" button 5.- Press "FORWARD/DND" button to change to the hour selection 6.- Press "TRANSFER" button and enter the hour 7.- Press "FORWARD/DND" button to change to the minutes parameter 8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter 10 Press "MUTE" button to select AM or PM 11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed) 12.- Press "HOLD" button 13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7731 Corded Phone
Changing time
2.- Enter programming mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
Messages on answer machine panasonic KX-T7730
3 to delete messages. These are instructions for a TVS system. It generally applies to the TVA system as well, with a few extra digits.
http://public.carl.airpost.net/TVS/VPS_retrieve.pdf
Carl
Apr 08, 2009 | Panasonic KX-T7730 Corded Phone
Trying to change our company greeting
When you record it, you press 1 immedately to stop recording. From there it will say press 1 to review and 2 to accept or 3 to record again or something like that. You need to select 2 to save.
Carl
Nov 21, 2008 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7731 Corded Phone Logo
201 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
