Hi Rachel,
The old monitor was set to a resoloution that is higher then you current monitor can handle. This is normally the case when changing from a CRT to an LCD
Try this:
Unplug the video cable from the back of your computer.
Start the computer and wait for about 2 minutes.
Press the power button on the front of the computer just once. This will **** it back down safely again.
Plug the video cable back in, then restart the computer with the monitor turned on.
If this dosn't work then try this:
- Turn the computer on (have the monitor already powered up)
- When the computers bios/splash page goes away begin to press F8
- You should get a Windows Startup options page.
- If you see the WIndows Logo you normally see when it loads, just hit the reset button and try again.
- In the Windows Startup page, select Safe Mode and press enter twice
- Windows will now load.
- On the desktop right click anywhere there is nothing.
- Select Display Properties, a new window will open
- Select the last tab at the top of the window (properties)
- You will see a slider on the left side, move it to 800x600, select apply, then close the box.
- Restart Windows.
If that fails, then please post back and we can try something else.
