Question about Vacuums
I can't get the pressure off the spring to put the new belt on 88 chevy van.
    Problem Solver:
  • 11 Answers
Have you tried a crow -bar?
Posted on Sep 28, 2010
Replacement of v belt
Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
THanks
Apr 02, 2012 | Vacuums
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
I have got the brush roller off but can't see how
You have to take off the bottom plate that covers the brushroll and put the belt on the brushroll. Then stick the belt into the slot going to the motor part of the vac. Then you can put the plate back on. Next, you have to take the top of the vac off. With the vac upside down,using a straight edge screwdriver and release the pressure locks. There are two on each side of the vac,one near the rear and one up near the brushroll. Just put the screwdriver between the top cover and the base and pry. It should be fairly easy. Then you can put the belt on the pulley. I use a phillips screwdriver to strech the belt to the pulley. This is the hardest part to do. The belt number is 38528-040.
I hopt this helped, Joe
Nov 16, 2009 | Vacuums
I can't seem to get the belt cover off of my Kenmore Progressive 400. There are two buttons that say above "belt and bulb change" but the buttons do not move. Do you know how I can remove so I can put a...
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Royal upright handle fork spring replacement
This is actually fairly normal, and there's no real easy way to get that bolt out. Your best bet is to continue turning it as if you were unscrewing it while applying pressure to the opposite end. A narrow piece of metal can help, especially if coaxed with a ballpeen hammer. If possible, you can try to apply some pressure upward on the spring to keep it from holding the bolt too tightly, but this only works about half the time.
Getting the bolt back into place is also something of a nightmare, as you have to use your thumbs to hold the new spring in place while forcing the bolt back into place. I've had indentations on my thumbs from holding that spring many times.
Good luck,
-R
Sep 22, 2008 | Royal 5300 Upright Vacuum
Lost roller on Savvy
need more info spring and washer don't tell me anything.do you have all the parts.i think your talking about the spring washer that keeps the brush roller from locking up.if thats what your talking about remove the bearing cap off the end of the roller brush.lay it inside the roller concave ppart of the washer down put the cap back on.if both washers came out of thesame side put the spring washer in first then the flat washer
Aug 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Problem with a WindTunnel 2 Extra Reach Bagless Upright (U8351900)
My dad fixed it by putting the spring under the arm lever and the roller on the outside part of the belt than in the inside as I have been trying to do.. I did however put one part of the spring in the right area of the vacuum. In a hole on the bottom area of the inside. The spring that is bent in a 90 degree angle doesn't go on top of the extend part of the arm lever but underneath. My dad did wounded the spring a bit tighter than it original is. That fixed what many days and hours of my frustration in less than 5 minutes (That's how long it approximately took my dad to fix it and in one try)
Jul 12, 2008 | Hoover U6660-900 WindTunnel Bagless...
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
