Question about Pentax Optio M20 Digital Camera
Battery depleted message after i just replaced batteries
I just put new lithium batteries in my camera and it still says battery depleted. I camera goes back to off and i wait about 5 to 10 minutes and try again, still the same problem.
  • billcody May 24, 2008
    The maker is pentax and the model is a optio m20 and the batteries are energizer lithium double A
    THE BATTERIES I'M USING ARE BRAND NEW ENERGIZER LITHIUM
    Genius:
  • 3,422 Answers
You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
If you still face the problem then the only solution will be to get it serviced as it can be a mechanical problem.
Goodluck,
Please don't forget to rate the solution
Posted on May 24, 2008
    Sergeant:
    Champion:
  • 230 Answers
The problem may be of the batteries check that first and also try by taking the battery out and then put and try. otherwise there may be some discontinuity in connections inside the camera check.............hope this info will help you
  • Pentax Master
  • 13,433 Answers
Do you have a charger for this camera? can you leave it on the charger for a while?
  • 3 more comments
  • Ekse May 24, 2008
    Ok, so this camera uses basic aa batterys. Try another set of batterys. If the same problem comes up. You have to send the camera in for service. As there is a hardware or a software fault in the camera.
    If you have warranty I beleave they will repair this for you, contact your dealer in that case.
  • Ekse May 24, 2008
    but also, tell me about the batterys that you are useing.
  • Ekse May 24, 2008
    This camera uses AA alkaline batteries- Are your lithium batterys charged?!
  • Ekse May 24, 2008
    Try another set of batterys to see if the problem is in the camera and not in the batterys.
  • Ekse May 24, 2008
    He did have a valid solution though.
    Sergeant:
    Champion:
  • 304 Answers
may i know the exact maker/model of your camera & the brand of battery you use..
`jack
  • Elizabeth Krijt
    Elizabeth Krijt May 24, 2008
    - yah please try to use another provided battery into your cam.. let see if you still have the problem..
  • Elizabeth Krijt
    - well here we go again, the coolguy008 is striking again
Hi, Have K200D and in the past few months am having problems with batteries....have always used energiser lithiums successfully but now it keeps bringing up the battery depleted message. If I switch off...
Before you do anything just make sure that the battery you use is a hot one. Then also check to see if you can reset the camera software to factory defaults - you may have to contact mfg for this. If no positive results you may have to resort to repair provided it is cost effective - may not be.
Sep 22, 2017 | Pentax K200D Digital Camera with 18-55mm...
I have a Coolpix L100. On 27 December 2010 after taking a few shots with flash, using rechargable batteries for one year, it displayed in Hungarian that the batteries are depleted, but after I have...
You will have to contact Nikon about any warranty claims. The standard warranty seems to be 1 year.
I have found that there is a firmware update for this camera that allows for support for Ni-MH rechargeable batteries (the original firmware only supported alkaline or lithium batteries). Try that firmware update to see if it resolves your issue.
Dec 27, 2010 | Nikon COOLPIX L100 Digital Camera
Using up batteries even when off
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 12, 2009 | Kodak EasyShare C315 Digital Camera
I keep getting a battery depleted message
I don't know but that would be wierd if this was Paula Meadows from McAlester
Sep 08, 2009 | Pentax K100D Digital Camera
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
S2 pro electronic malfunction?!?!
If your lithium batteries are depleted, having them in the camera will shut it down. A common cause of depleting the lithium batteries is leaving them in the camera while using the AC power adapter. For some odd reason, the Fuji engineers did not build in a disconnect circuit when on AC power. You should always remove the lithium batteries when using the AC adapter.
The Fuji S2 will run fine without the lithium batteries, except that you will not be able to use the built-in flash. Fuji recommends that as an "emergency" procedure, but I ran my S2 off NiMH AAs only for my heavy use over four years with no adverse effects.
If you buy the MB-16 battery pack or one of the modified versions for the S2, you would be able to use 8 AA batteries to power the camera, including the built-in flash, and never touch another lithium battery. The MB-16 itself does require some modification in filing off edges around the base and building up material around the post to firmly engage the switch you found.
Sep 29, 2007 | Fuji FinePix S2 Pro Digital Camera
My camera won't work at all it just says batteries depleted even with new batteries
try taking the camera to ur local hp dealer and smash it to the ground jump up and down shouting i feel better now ha ha ha ur all nuts michael
Jul 05, 2007 | HP Photosmart M425 Digital Camera
Pentax Optio M20 Digital Camera Logo
106 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
