Have a williams 465fa pilot lights but the heater wont kick on. Tested thermostat but still no heat.
    Sergeant:
  • 235 Answers
There is a sensor right above the pilot light. Your pilot light might be on, but your sensor is not seeing it as being lit and will not allow the heater to come on. You can pull that sensor off and clean it with fine emery cloth or just go buy a new sensor. The cost of the sensor shouldn't be more than about $20 bucks.
Posted on Sep 28, 2010
Williams wall furnace
Thermostats aren't very expensive. You can get universal ones at home improvement stores.
Dec 06, 2016 | Williams Heating & Cooling
Once the heater reaches the set temperature at the thermostat it shuts off.the flame goes out but the pilot light stays on. the heater will not kick back on automaticaly when it gets cold however it will...
you will have to look into why the unit is tripping and needs resetting. Heaters usually have a fan delay, meaning that when the heat is satisfied, the fan continues to run for about an minute. If not, it could cause an overheating issue and trip a safety. Look for that to start with.
Aug 05, 2017 | Williams 3003622 Ceramic Wall Mounted...
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Williams 3003622 pilot light is on but heat doesn't turn on- there is a "Do It" thermostat connected. Is it a problem with the thermostat or furnace?
Try jumping out the thermostat (red and white wires) that run to the thermostat these tell the heater to come on. Jump them together if you have heat it is the thermostat, if no heat it is the furnace. Should it be the furnace I would first check the thermocouple or some manufacturers call it a flame generator. Clean this with steel wool and position it in the top center area of the flame as this is the hottest part of the flame. Good luck
Dec 26, 2010 | Williams 3003622 Ceramic Wall Mounted...
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
Motor kicks off and on , off and on, on my wall furnace. It blows for less than a minute, then winds down, then kicks on again. Williams 465FA
the thermocouples go bad on those and the gas wont receive the signal that theres is a flame present replace thermocouple
Jan 12, 2010 | Heating & Cooling
I HAVE A wILLIAM wALL hEATER. tHE PILOT LIGHT IS
The blower is heat activated, it takes more than the pilot. If the burners are on, verify power to the unit.
Jan 01, 2010 | Williams Heating & Cooling
Williams Model 435FXR Serial GO222436 Forced air pilot keeps going out
BY THERMISTOR, ARE YOU MEANING THERMOCOUPLE, I.E. WHAT YOUR PILOT LIGHT IS HEATING? IF SO, COULD BE WEAK AND NOT GENERATING ENOUGH VOLTAGE TO STAY OPEN, SHOULD BE BETWEEN 10-25 MILLIVOLTS DC, WHICH CAN BE TESTED AT THE INTERRUPTER LEADS. YOU CAN ALSO BYPASS THE LIMIT DISC TEMPORARILY TO SEE IF THE UNIT STAYS LIT, REPLACE IT IF THE UNIT RUNS.
Jan 28, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
167 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
