Question about Dewalt DC925 Cordless Drill
DeWalt DC925XE Keyless chuck keeps undoing when reversing screws releasing driver bits.
You must never oil the chuck so if this has been done then it can be the cause of your problem
Posted on Sep 28, 2010
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
How do you release the bits to change sizes
It is a keyless chuck. You should be able to grab the main body of the chuck and turn it to the left to release the bit. You can also hold the main body of the chuck and run the tool slowly in reverse whcih will also release the bit.
Jul 10, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Cannot get the chuck to release the bit it is a dewalt and yes I am in reverse
On some of the DeWalt drills I have owned with keyless chucks, the chuck has a locking mechanism.
You have to grip the chuck and slide the outer sleeve forward to release the lock, then you can tighten or loosen the chuck.
Apr 14, 2011 | Drills
I have a new DeWalt DC725 cordless compact 1/2" drill/driver/hammerdrill. The only problem so far has been that the keyless single sleeve chuck will now not open to release a 1/2" drill bit. I have twisted...
place the bit in a bench-vice and take a little benchhammer and with a plastic hammer .
hold the hammer with chisel tip on the claws of the chuck and tap with the plastic hammer on the other side of the bench hammer and beat gently on the three claws tighten the chuck three-step around gently around so the bit slowly from the drill bit comes slowly loose.
if the bit is out you can turn the chuck free, if this problem repeats go to the dealer for warranty .
Aug 17, 2010 | Dewalt Garden
How to change the drill head
If you man changing the chuck, take out any drill bits and look down into the chuck. You will see a screw holding it on. On many drills this screw has a reverse thread so it loosens in the opposite way to regular screws. You have to undo this screw to remove the chuck, then fit a new one of the same spec or one suitable for the drill and reassemble in reverse order.
Mar 31, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My drill 1/2" drill bit is stuck in my drill how in the hell do I get it to release???
Put the bit in a vise and try hittig the reverse button.If that does not work the tap the three lock tabs in the end of the chuck with a punch and you should be able to undo the chuck.
Jan 21, 2010 | Dewalt 18 Volt Compact Drill Kit
I put a short bit into my dewalt impact driver and now i cant get the bit out
Switch to reverse and driver mode hold tight the chuck then run the drill just to jack it... be carefull the keyless chuck plastic that release is easy to lose its grip to the steel so be patient. goodluck!
Dec 12, 2009 | Dewalt Drills
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC925 Cordless Drill Logo
332 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
