Question about JVC LT-26X506 26 in. LCD Television
I have a JVC 26x506 which is only 4 and a half yrs old and it won't turn on. No sound, No lights, no nothing!
  • 113 Answers
SOURCE: JVC AV-F29MX3
You have what sounds like a failing vertical output IC also could be some bad capacitors. If you are able to solder it would cost a few dollars to try this and see if it fixes it. If not you would need to replace the whole board itself and that could cost you a little bit more money. If you need a tech it is time to get rid of it you are looking at at least 200 dollars for repair.
Posted on Feb 06, 2008
VOTIT
  • 2071 Answers
SOURCE: tv shutting off timer light blinking
Your TV is in the protection mode. First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 30, 2008
jhinsincity
  • 616 Answers
SOURCE: JVC TV Sleeping
Indicates a power supply failure, needs a few filters replaced expect to pay $100-150 Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
kenw392
  • 2226 Answers
SOURCE: jvc kd lx30 lit up
You might want to check your speakers and speaker wires for shorts and/or grounds.
Posted on Jun 24, 2011
dunnbiker
  • 8546 Answers
SOURCE: Jvc RX 8020 receiver won't
I'd suspect one of the controls that would be overriden by analog direct is unknowingly activated. LOOK at the front panel and interpret every indicator for how it could cause silence. Refer to the manual for those you don't understand.
Any Tape Monitor activation would disable digital sources completely.
See page 14 for how Line Direct affects DSP modes.
Posted on Jun 27, 2011
Lt 50a330 jvc
I was watching my tv model LT-50a330 JVC and it made two popping noises and the screen went balck but the green power light stayed on. I unplugged it and could smell something bad like a short. I havnt tried to turn it back on, does this mean I need a new tv, it's not even two yrs old.
Aug 02, 2013 | Hitachi L42A403 42 in. LCD HDTV
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
2001 Yukon SLT, engine will not turn over - friends think it's the alternator. Battery is 2 yrs old. My friend tried to jump start it, that did nothing, still won't stay turned on. I got the...
Hi there !
I won't say its an alternator problem because the alternator only charges the battery when its on, And it should start with the jump cables even if the battery and the alternator are bad. your Issue is not clear. Does the car start when you jump it ?
Aug 15, 2011 | 2001 GMC Yukon Denali
JVC AV-F29MX3 I was watching a film on my DVD connected to the TV, when suddenly the screen turns black with no sound heard. Also the front light indicating 'ON TIMER' and 'ECO' started blinking in red...
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective .................. so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective.......... price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore ( 09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact jvc service centre.........
Apr 21, 2011 | JVC AV-F29MX3U 29" TV
JVC TV Sleeping
Jul 23, 2009 | JVC AV-27320 27" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
JVC AV-F29MX3
Feb 06, 2008 | JVC AV-F29MX3U 29" TV
JVC TV-AV29TS4
How old is the TV? Usualy the most common problem with these Projection TV's are the LAMPS. They can last anywhere from 1 yr to 3 yrs. They usualy need to be replaced after 1yr and a half (18 months). Manufacturer's usually warranty them for that period of time. There is an access panel in the rear of the TV. If you open this panel you can see the lamp. Check it and see if it has gone out.
Jan 07, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc 48" tv model av-48wp34
Sounds like you lost the High Voltage. The beating sound is the power supply trying to start up. After a predetermined time it will quit to protect the set. This is a very common problem and typically not that much to repair. If you are not an electronics repair technician you should find a reputable repair shop and enlist their services. I would not think the cost should exceed $150.00 to repair. Good luck.
Jun 18, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC LT-26X506 26 in. LCD Television Logo
50 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
