Question about Zebra 105SL Thermal Label Printer
105SL is taking template from Label Matrix and stretches it so the data matrix part is unreadable when scanned. How do I make it take an existing template and retain the print size, font and 2D?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Check to make sure you have a 105SL printer driver. Also check to see if you have chosen ZPL for the language as well as the proper resolution (203, 300 and 600 dpi).
Posted on Oct 12, 2010
Casio fx 191es
Use the Matrix Computational mode.
Select a Matrix label A, B or C Press EXE
Select the dimension (mXn)
A template opens to allow you to enter the coefficients.
You need to read about what kind of operations you can perform on matrices (addition, multiplication, raising to a power, etc.)
Nov 29, 2013 | Office Equipment & Supplies
How to enter matrix to the calculator
Turn calculator ON
Press the Mode key.
Select the Matrix Option
Select the name of the Matrix: MatA , MatB, or MatC
Choose the dimensions of the matrix (3X3, 3X2, ..2X1)
Calculator displays a template (empty spaces where you enter the matrix coefficients.
Type = after each element.
Press AC to exit the matrix editor.
Now you are ready to do (legal) operation on the matrix.
Available opeartions are found under SHIFT 4: Matrix.
To enter a matrix label on the command line (MatA, MatB, or MatC) you press SHIFT;4 (MATRIX), and select the label by pressing the relevant number in the list of options
Jan 24, 2012 | Casio FX-115ES Scientific Calculator
How to enter the matrix
Open the ScratchPad/calculator application then press MENU.
Use arrows to highlight Matrix/Vector or just press 7
Press 1 Create then 1:Matrix
Choose/Enter the dimensions.
Highlight the OK button and press ENTER. The screen displays a template of your matrix.
Enter matrix coefficients.
If you plan on doing something with the matrix, you have to give it a label (name).
Aug 28, 2011 | Texas Instruments TI-Nspire Graphic...
How can i print a label of 9cm x 5cm
Publisher allows you to create labels on A4 paper of whatever size you need; it also includes a large collection of templates for more common label companies.
Mar 03, 2011 | Epson LX-300+ II Matrix Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
How do get the determinant from a 4 x 4 matrix
To create the matrix (in case you do not know.)
  1. Press [2nd][X^-1] to access the (MATRIX) menus.
  2. Use the right arrow key to move to the tab [EDIT]
  3. Under tab EDIT, press 1 to name the matrix as [A]
  4. A matrix template opens (default dimensions are 1x1)
  5. Change the dimensions to 4x4: Press digit 4 key and ENTER. Cursor move to 2nd dimension. Type in 4 and press [ENTER] to validate.
  6. The matrix template changes: screen shows a matrix, filled with 0.
  7. Enter the value of each coefficient and press [ENTER]. The cursor move to next coefficient.
  8. After you validate all values, press [2nd][MODE] to (QUIT) the matrix editor.
To calculate the determinant of a matrix that is already defined.
  1. In main calculator screen press [2nd][X^-1] to open the (MATRIX) functions.
  2. Use the right arrow once to highlight the [MATH] menu.
  3. Select [1:det(] and press [ENTER]
  4. The command det( echoes on main screen.
  5. Press [2nd][X^-1] to opent the (Matrix) menus again.
  6. Select the number in list that corresponds to your matrix (presumably 1:[A]) and press [ENTER]
  7. The command line shows det( [A]
  8. Complete the command by closing the parenthesis and pressing [ENTER]
  9. Wait for the result to be displayed.
Nov 01, 2010 | Texas Instruments TI-83 Plus Calculator
The printer adds an extra line space at the end of every label I print, by the 4th label they aren't usable
You could fix this in the printer, but faster and easier to alter your program's printing function. Check that you are using the correct form template, and either delete one line from your data, The program may be issuing a line feed, or modify the form dimentions.
print on blank paper until you get it dialed in. Hold up to light and lay labels over or under it to see alignment
Oct 15, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
Can't do inverse of matrices
The problem is with the data. The calculator is telling you that your matrix is singular. Inverting a singular matrix is analogous to dividing by 0. Just as you can't divide by 0, you can't invert a singular matrix.
If you think that the inverse exists, double check the entries in the matrix.
Apr 19, 2009 | Texas Instruments TI-83 Plus Calculator
Texting signature on pantech matrix
no, i've researched it and there is none...:(( but you if make a template you could put what you want on there then go to that every time you need a message
Apr 10, 2009 | Pantech Matrix Cell Phone
New 105sl printer isn't getting data
What kind of serial cable are you using? Null modem? Also you could try a lower speed
Apr 08, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
184 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
