Question about Garden
Nordan door is hard to close shut and door knob hard to press down
5 Suggested Answers
c17hydro
  • 2984 Answers
SOURCE: Doors are very hard to shut on my 1988 Dodge ram
Actually you can adjust the catches that are part of the door by loosening them enough to slide them towards the OUTSIDE of the door....then tighten them back up.
Posted on Mar 14, 2009
  • 603 Answers
SOURCE: When I press the button on my transmitter, the
You have a sensor problem. Either it's not lined up right or one or both sides is bad.
Check for the lights on each side of door at the garage floor. One is most likely out. Make sure they are pointing at each other.
If it looks straight, then you have to get a new ones to fix your problem.
I had to do this on mine just a month ago. I found them on ebay - $24.
Posted on Jan 14, 2010
SOURCE: When I close dishwasher door, I have to press hard to lock the door. Is this normal?
check the catch where the door clips into. It might be loose. If so tighten the two phillips screws, then try to close the door.
Posted on Nov 16, 2010
edwardjwoods
  • 372 Answers
SOURCE: When the door is closed the engine shuts off?
the system is shorted between the door pin and the pcm
Posted on Apr 18, 2012
Chevy trailblazer problems
its either a bad door switch,or could be the dome override switch by headlight switch,or your interior light switch is all the way up
May 01, 2014 | 2004 Chevrolet TrailBlazer
Garage door will close, stays shut for a few seconds and then opens on its own.
The opener is closing too far. On the side of the opener, you should see 2 white knobs, recessed into the side. Using a flat blade screw driver, adjust the close knob (closest to the door side of the opener), anti-clockwise until the door will close gently on the floor.
Aug 24, 2013 | liftmaster Garage Door 1/2 Hp
My isuzu trooper driver door won't unlock
If the door wouldn't close how did you close it to lock it and have to exit out the passage side door? Anyway if the door is open like you said and it's locked you can easily access the locking mechanism without removing the side panel. It's on the side of the door, not the inside and not the outside, but the thin strip visible only when you open the door. There will be two metal pieces that clasp together. You can separate them manually, this will unlock the door.
Jun 13, 2017 | Cars & Trucks
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Door closes then goes back up
it needs adjustment, there are usually an adjustment knobs on the unit it self, (check from the owners manual)...
Jul 10, 2011 | liftmaster Chamberlain Garage Door Opener...
The Driver's side door of my 2002 nissan altima does not shut properly. The door opne indecator light on dash stays light and door don't close like the other doors. Mickyd.....
you need to loosen up the little round knob on body of car and adjust up or down till it closes right as long as your door pins and hinges are not worn badly, good luck
Dec 28, 2010 | 2002 Nissan Altima
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
I'm not sure what you were told but the (knobs) are the strikers. Do the latches in the door line up with the strikers? Do the doors hang straight? You might need to adjust the hinges or the striker. If it all does line up then you might need a new latch.
Mar 14, 2009 | 1988 Dodge D-Series Pickups
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
