Question about Sharp AL-1642CS Copier
The letter H and a number 4 appear alternately on the display
  • 1,110 Answers
To reset the H4 condition on your Sharp AL1642 series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
Posted on Sep 28, 2010
4 Suggested Answers
  • 132 Answers
SOURCE: My Sharp AL 1000 is displaying alternatively the
Hello
The error that is on your disply is the following.
The fusing temperature does not reach 175 degrees celsius within 30 seconds of turning on the power, or the fusing temperature keeps at 140 degrees celsius.
In sequence press the following buttons [clear]-[density select]-[clear]-[desity select] the display will go blank.
With the copy quantity keys input 14 and press the start/print button, the machine will cycle.
If the error returns then the thermistor and themo fuse will have to be rplaced.
I hope this helps you
Regards
Posted on Apr 16, 2011
  • 148 Answers
SOURCE: my copier AR-5320E is showing a number 4 and letter H
the fuser unit is not heating up
unplug the copier then plug back in
make sure the fuser area where you clear jams is latched down
close all doors
if this does not work your fuser lamp is burned out or a fuse has blown on the heater roller
You will have to call service
Posted on Jan 07, 2009
  • 87 Answers
SOURCE: Letters and numbers appear in the display
L6 SHOWS LASER PROBLEM MOTOR MAY BI SENSOR.AND L4 DRIVE PROBLEM MAIN MOTOR OR MAY BI ANY GEAR IN DRIVE.CHECK ALL GEARS .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Posted on Feb 22, 2009
H and 4 appears alternately on SHARP AL-1226
Press the key simuteniously C ,Density Key& C Then press 14 and press start key, then machine auto restart. ok
Dec 17, 2013 | Sharp Office Equipment & Supplies
A letter and number appear alternately
What Letter and What number?. These usually come up as L - 1 or H - 4...both of which are easily resolved. Just let us know what code is flashing.
Feb 03, 2011 | Sharp AL 1631 Copier
How can ii unlock a blackberry.?!
How To Enter the Unlock Codes on a BlackBerry Cell Phone
422851199_3d16b31e6c_o.pngModel : All BlackBerry Models (except T-mobile)
1 – Using the menu go to Settings Menu -> SIM card press select.
2 – While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 – You should now see the five locking categories listed.
4 – While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 – Release the shift key.
6 – You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 – Enter the code
8 – Enter Return/Enter
9 – The device should then be unlocked
Model : T-mobile BlackBerry Models
1 – On the Home screen, click the Tools icon. The Options screen appears.
2 – In the tools screen, select the Settings icon.
3 – Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 – Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 – Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 – Input the Network Unlock code
7 – Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 – While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 – Choose “Advanced Options”.
3 – Select “Sim Card”
4 – There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 – Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 – Input the SIM Unlock code
7 – Press in the trackball in once
Your phone is unlocked
Apr 10, 2010 | Cell Phones
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
Al1631 sharp copier
This is called error code which you must specify.For H2,H3,H4, use command 14, for U2 use comm 16.Please specify if neither of this displays.
Oct 02, 2009 | Sharp AL 1631 Copier
Feb 19, 2009 | Sharp AR-5320 Black and White Copier
Unlock blacberry pearl 8100
hi there :-)
try this i havn't done this but my friend does now he uses any sim on his pearl.
Pearl instructions - Can be done without a sim card inserted
To Unlock:
1. While on the home screen, click the "blackberry key" on keyboard, then select "options".
2. Choose "Advanced Options".
3. Select "Sim Card"
4. Type m e p p 2 to display the dialog box asking for the unlock code
( you will not see text appear on screen while typing )
5. Input the SIM Unlock code
6. Press in the trackball in once
Finish :-)
peace!
Dec 09, 2007 | Nokia 1100
407 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
