My monitor 441 works properly on startup procedure until comes the time for the circulation fan to come on, which it doesn't. what are the possible problems am i facing?
  • 3 more comments
  • jjdecker76 Sep 28, 2010
    so where is the relay located as i want to be sure. Electrical troubleshooting is not my strong suit.
    so the circulation fan doesn't come on when the monitor tries to initially start up. it was mentioned to me to test the relay or the control power board or the fan, but if someone can try to walk me through the testing procedure that would be great as electrical is not my strong suit
    so the relay is on the power control board itself?
    it's labeled "D" and when diconnected there's three prongs sticking out which ones do i test with the meter
  • jjdecker76 Sep 29, 2010
    Thank you for your assistance as it was a wiring problem and now it works fine. and I learned a lot in a little time. Now I know where to go for any problems down the road. Thanks again!
    Genius:
  • 1,416 Answers
What this problem simply means from your statement is that there has been a loose wire from the fan connection.
What you need to do to fix up this problem is to carefully unscrew the screws of the air condition after you most have gotten the system (air condition)closer to you then trace the wire that supply power to the air condition carefully check on the fan connection and fix up the loose wire from it position note, this if the wire connection look okay then it means that the fan it elf will need a little service or replacement
to do just this you will have to make sure that the have been remove from it position .
hope this solve the problem ?
thank you and thank for using fixya.
Posted on Sep 28, 2010
  • 2,299 Answers
Either the relay that turns the fan on is not pulling in or the fan motor itself is burnt up. The PCB or power control board could also be the problem. Not pulling the relay in. It could be any of the three. You can check the relay to see if you are getting the 24volts to pull in the relay. If you are getting the 24volts. then the control board is ok. Then if you are getting power on both sides of the relay, then the relay is ok. If the relay is sending power to the fan, then the fan is bad.
  • Rodney Clark
    Rodney Clark Sep 28, 2010
    The easy way to tell you is to follow the wires from the fan motor. The wires go to the relay.
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
Oct 20, 2011 | De Dietrich Ovens
Tells me I'm in a power saver mode. Screen is blank. Model is 2241V
That message comes up when the monitor doesn't get a signal from computer, and enters power save mode until computer comes on. This usually means that the computer's not starting up when you turn the power on. It may also mean that some problem has occurred with the computer's video circuitry.
Begin by checking that the computer is actually starting up properly. Look for the normal startup signs (lights on the computer showing power and disk access, fans running, sounds through the speakers). If you're sure that the computer is working and getting into Windows, try another monitor. This will tell you if the monitor is bad or if there's a video issue with the computer.
Jun 03, 2011 | LG Computers & Internet
Hi, My samsung RT26m is not cooling properly & all the vegetables in refrigerator getting ready to through away. I think cut off switch (Rely ) is not working. pl give me solution as early as...
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Apr 08, 2011 | Samsung Refrigerators
Freezer not working ; making unusual noise which is intermitten; removed bottom panel in back sounds like may be compresser but I CAN't be sure; refrigerator compartment is still working. Noise lasts...
Good luck.
Mar 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer not getting cold
Good luck.
Mar 29, 2011 | Refrigerators
Reefer is working fan in freezer is working freezer is not freezing
Good luck.
Mar 22, 2011 | Refrigerators
Reefer is working o.k. Freezer is not working. Blower in freezer is working
Take care.
My freezer do not work, the light is on in the bottom
Good luck........
Mar 22, 2011 | Frigidaire Refrigerators
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
