Question about Meade Optics
Just bought etx-ls 6" while updating handset had a power cut now the handset is blank and telescope inoperable what can i do to get my scope back up and running
  • 3,186 Answers
Read this web site -- the third post down from the top explains how to recover using "safe load".
http://meade4m.com/forum/index.php?topic=3180.0
Posted on Sep 28, 2010
I have a Meade ETX-70. When turned on, the handset says there is a Motor Unit Fault: Motor failure detected due to moving handset between scopes, low battery level, obstructed or overloaded scope. I've...
This is usually caused by low battery power-- as the hand controller reported. DO NOT USE rechargeable batteries they do not have enough volts. Use alkaline batteries only.
This can also be caused by a broken gear or a failed internal motor. You can return these to Meade for repair.
Here is the contact number:
http://www.meade.com/support/index.html
Sep 14, 2011 | Meade ETX-70 (240 x 70mm) Telescope
I just bought a used ETX125 PE the motor that lifts the scope seems to power out,or simple cannot swing up!
Are you using the internal batteries? Are they fresh and fully charged?
Replace them and try again; or better get a seperate 12 volt power pack and the correct Meade 12 volt cigarette lighter style power cable.
Feb 27, 2011 | Meade ETX-125PE (500 x 127mm) Telescope
My whole lense has snapped of the base of my meade 90 etx
Meade can repair these scopes but they will want you to return the scope--
Contact them here:
Jan 20, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
Red wire from battery off, where does it go?
It broke off of the circuit board. Actually I PURPOSELY cut both of the battery wires OFF! This makes it much easier to work on the internal gears.
Just buy a separate 12 volt power pack and stop using the internal batteries. The scope functions better on a regulated separate power pack. Buy the proper 12 volt cigarette lighter style power cord.
I never use the internal batteries and have removed them completely from the scope. If they leak they will ruin the circuits inside the base of the scope.
Nov 28, 2010 | Meade ETX-90EC (325 x 90mm) Telescope
I have an older ETX Astro Telescope or ETX spotting scope. A small rectangular mirror has come loose in the main body of the telescope. It appears undamaged. Is there a manual that shows me how to place...
This is a known issue with the older ETX scopes. You can use silicon sealant or a small amount of hot glue -- and just put the mirror back on it's small platform.
However you might need to disassemble the rear of the scope to do this. See this web site for instructions on disassembly.
http://www.weasner.com/etx/menu.html
Sep 08, 2010 | Meade Optics
Power goes out ETX 125
Several possibilities:
1. Bad cable from hand controller to the scope. Buy a new one at www.scopestuff.com much better quality and cheap.
2. Firmware is corrupted in the hand controller. Update the firmware using the Autostar Update software here:
http://www.meade.com/support/auto/Au2ver59.exe
3. You have a bad hand controller and will need to buy a new one.
Never plug or unplug the hand controller or any other cables while the power is turned on.
Good luck--
Mar 20, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
Meade ETX 80 telescope missing parts
You are missing a screw on cap for the rear port, and you need to buy several 1.25 inch eyepieces.
Scopestuff.com sells the rear port cap also you may be able to get one directly from Meade- http://www.meade.com/support/index.html
Several internet retailers sell 1.25 inch eyepieces.
Here is one:
http://www.agenaastro.com/
Feb 21, 2010 | Meade ETX-80AT (240 x 80mm) Telescope
I have a Meade ETX 60. The internal threaded rod that focuses the telescope is broken. Can I get a replacement ? I already have this taken apart and have removed the rod.
You can call Meade, they might sell you a rod??? Usually they want you to send the scope back to them for repair.
Nov 08, 2009 | Meade ETX-60 AT Telescope
Meade ETX-125EC Telescope Problem
Well, when I got the unit, indeed it would not power up at all. I could see no burning or signs of arcing.
I looked online for an internal picture of the drive and fitted the cables back in according to the image.
Tadahhhh, one working drive, only works on the 12v though, Batteries wont work although I have measured the voltage and they are all fully charged. Seems the previous owner had removed the looms and put them back incorrectly.
Mar 14, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Optics Logo
298 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
