Question about Emerson Audio Players & Recorders
Emerson HT200 Theater System
Husband Recently purchaced this system used, it has no manuals or instructions . I do not know how to connect the receiver to my home system. IE: Tv...DVD...or DIgital cable box connections. We have everything but the manual. Can someone please help me with where the audio plugs will be going?
3 Suggested Answers
SOURCE: Need a Manual or help with System
YOU NEED TO HOOK YOUR RCA CABLES FROM YOUR DVD,TV,AND DIGITAL CABLE TO THE INPUT SIDE OF THE SURROUND. HOOK THE RCA CABLES FROM THE TV TO THE AUX SIDE AND THE DVD TO THE VCR INPUT, AND THE DIGITAL TO TH LD SIDE OF THE INPUT YOU CAN SWITCH BETWEEN THE 3 ON THE FRONT OF THE SURROUND.BY MOVING THE KNOB. YOU WILL GET NOISE FROM THEM THEN TO THE SPEAKERS.
Posted on Apr 28, 2009
electrepairu
  • 195 Answers
SOURCE: Can't get my Kenwood VR715 receiver to go into the Select a speaker system to see if speakers are turned on. Followed manual instructions and can't get in. Any Suggestions.
Try resetting the unit by unplugging the unit from the wall, then plugging it in again WHILST holding the power on/standby button in. This should reset the system. If not:
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Posted on Jan 07, 2017
Need user manual for Emerson HT-300b
look at emerson.com and the home page should have a manual that you can look through. hopefully that works!!!!!!
May 03, 2011 | Emerson HT200 System
I don't know how to use the remote controle to turn on the surround sound, can you tell me what button to push? My husband threw away the instructions.
You can download the manual & print it out here: http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
Jan 31, 2011 | RCA RT2910 Theater System
My Philips Dvd home theater system HTS3100, how can i connect to my tv set
Hello
1. First things first, READ the Instruction Manual, I know most of you guys out there hate reading the instruction manuals but every system is different, so I'll generalize this article for an average system you can find at a retail store today.
2. Make sure you have the right cables to connect your TV to your Home Theater System, now days the best connection is called "HDMI" (High-Definition Multimedia Interface) this cable uses a digital signal to transfer both video and audio while giving you the best quality possible. But please make sure your Home Theater System has the "HDMI" as an input option. If it does not, you might have to resort to a analog connection such as "Component Cables" which will provide you with a High-Definition connection but with analog quality.
3. Now if you are using a current TV and a current Home Theater System and your system is able to use the "HDMI" cable, connection to said devices will be pretty easy, just hook one end of the "HDMI" cable to the "HDMI" input on the back of the TV, and the other end of the "HDMI" to the "HDMI" output on the back of the Home Theater System. Turn your devices on and make sure your input/outputs are configured for "HDMI" usage and vola! You should now be able to see and hear everything your heart desires!
4. Organization is key, after you have checked your connections and everything is working the way you want it to, utilize the cable/wire loom to organize your cables and use the zip ties to secure them in place, not too tight though, if you want to change things around in the future it's easier to cut the zip ties if you have enough room between the cable and the zip tie.
THANK YOU
Jan 27, 2011 | Philips HTS3100/05 Theater System
How do you get the back speakers to work?
assuming you have plugged them all in correctly, it's just a case of scanning through the surround presets. Some presets use 3.1 channels, others use all channels.
Jan 07, 2011 | Emerson HT200 System
When i plug the emerson ht 200 the power button flashes twice then nothing?
Your fan is bad.
The system is intelligent. It knows the fan is bad, and it knows it will overheat without it.
It's throwing its self into a self-protect mode.
Have a tech check your fan.
Problem solved.
Nov 17, 2010 | Emerson HT200 System
How do i connect it to my tv so i can have surrounf sound when watching tv
if you look at the instruction manuakl that came with the theater system:
http://www.retrevo.com/support/RCA-RTD3133-Home-Theater-Systems-manual/id/23608dj495/t/2/
under connections and set up there are two ways of connecting up a tv
hopefully your tv has a audio out phono jack
using phono jacks connect the audio out from the tv to the AUX in the theather system
then select AUX in the theater system and then press the surround button to select sound modes
if your tv does not have a audio out jack look for a optical digital out socket in the tv and then use that to connect to a optical digital in in the theather system
May 11, 2010 | RCA RTD3133 Theater System
I recieved this system recently as a gift. No instructions with it to set it up. Where can I go on line to get instructions?
You can download the required manual from:
http://www.retrevo.com/support/Samsung-HT-Q80T-Home-Theater-Systems-manual/id/287bh740/t/2/
On the page which opens, click on the "GET MANUAL" button and follow the instructions on the next page to download the manual.
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 12, 2010 | Samsung HT-Q80 System
HOW DO I CONNECT MY DVD THEATER SYSTEM TO MY FLAT PANEL TV?
just either use rca jacks from the dvd to the tv,,u know ..the red,yellow,and white cables,,,,that will do it,,,using the rca jacks ,,make sure to set the the dvd/reciever settings to anolog
May 17, 2009 | Durabrand Televison & Video
Onkyo HT-S5100 Theater System
It's possible that you have the wrong speaker set (A or B). Look for that button and change the setting and see if that works
Mar 25, 2009 | Onkyo HT-S5100 Theater System
May 24, 2008 | Emerson HT200 System
69 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
